Spec me a secondary non-gaming graphics card
8 Jan 2019
MSI HQ
Ok, i've checked with Akasa too and their adapter & adapter cable are also DP 1.2...
My Akasa contact is going to check in with their Taiwan office on Monday so fingers crossed they have something :)
8 Jan 2019
MSI HQ
OP
1 Apr 2014
Aberdeen
OP
1 Apr 2014
Aberdeen
Yes thats the correct Stock Code. Not sure why the link doesnt work though.
Received with thanks. Unfortunately it doesn't work. More precisely, Windows sees that there's a monitor there and can identify the monitor but I cannot enable the monitor in Display Settings. I tried it on both the USB C port on the GPU and the one on on the motherboard. I'll email Startech for advice but if you have any, please let me know.
8 Jan 2019
MSI HQ
Morning @Quartz
I found this in the data sheet - "Your USB-C port must support DisplayPort over USB-C (DP Alt mode) in order to work with this adapter."
If the monitor doesn't support this feature I think you will be back to square one. I don't see anything else that could be causing a problem :/
I've included the link to StarTech's data sheet below for further referrence.
https://www.startech.com/media/products/CDP2DP14B/PDFs/CDP2DP14B_Datasheet.pdf
8 Jan 2019
MSI HQ
My GPU is a Gigabyte GeForce RTX 2080Ti WindForce OC. Perhaps @GIGA-Man can confirm whether or not this is supported? The specification page doesn't mention it. Failing that I fear I will have to return the adapter.
Don't worry if you have to return it, thats what the returns policy is for :)
I'll always try and help find a solution for our loyal customers where possible.
