Yea I'm on top of the maintenance, it also has a fresh water system that generates chlorine from the salt water.
I take it you have a good hand on the water chemistry? I'm assuming it uses cartridge filters? Do not neglect changing them!
The HotSpring uses a system called Fresh Water - you add salt to the water one time then a cartridge will produce chlorine at the output you select on the digital display. The cartridge lasts 4 months and you get 12 months supply. Everything else is pretty straight forward - use a strip to dip in the water and potentially have to adjust the Alkalinity / PH. Every 10 days the filters need to be removed for a clean and a dose of non-chlorine shock is added. Every 12 months empty and refill water.
https://www.hotspringworld.co.uk/freshwater-salt-system/
What some people think is the best beer in the world!
4 x Westvleteren 12
4 x Westvleteren 8
It's certainly hard to get hold of compared to most others :)
PBT key caps arrived. 95% of the keys match, it's a tricky layout. I have another set coming that may be better.
Custom cable is on order with hipster aviation connector.
Really nice board that, I've just recently purchased a 60% anne pro 2 but feel like I'd have been better off going with a 65...
Forum member @glitch kindly got this strap for me from the US of A recently. Saved me a few bob in customs fees :cool:
New shoes with high'ish sides, almost boots. Suede leather, not bad for £28. First photo makes them look brighter colour than they are. Very comfy.
New paisley shirt. Primark :p
Just hope it doesn't get cancelled by Corona. Managed to watch the 1979 Alien 4k Remaster this time last year so continuing a trend, right on my birthday as well :)
Yep.
Could have a 2.5t for another £30 but wasn't quite as low and 1.5t is ample for swapping wheels on a 3 series coupe. Actually need to take the fronts off tomorrow & arch liners out to change headlight bulbs :o hence the purchase.
Fed up driving the car up on to boards/blocks to get my old jack under it.
Damn you! Ordered one now plus some axle stands. GRRRRR.
