DRAM Calculator
19 Jan 2019
Co. Down, N.Ireland
Hi Guys,
Tried using the DRAM calculator to manually change the timings. So once run memtest86 once it gets to test #6 starts to show two errors. Don't get no BSOD or anything before hand even with Xmp. Any ideas?
Thanks
Kev
If your getting errors then it's not stable so you would need too adjust timings or try bumping the voltage.
Are you trying safe or fast timings?
What are the timings when you set xmp?
3f8p3jG
Ok what I would do is dial in 3600 speed in the dram calc and see if you can run with the timings it spits out at either safe or fast.
Running 3600/16 is the sweet spot on ryzen 3000 and maybe easier to achieve stability over 3200/14 and will also perform slightly better as you get the benefit from a higher infinity fabric.
Set the speed on dram calc to 3600 and try safe timings.
OK mate, also the section with trfc and trfc(alt) in bios I've got trfc 1/2/4 which changes to the same for all? I've just left on auto.
When I run memtest if I get errors would you increase the voltage slightly?
What's the highest you would go to?
Hi @Joxeon
Just wondering if you can help me improve latency. On the dram calculator it says best result is 108. 5 and my current result is 128.42 for 3600.
Everything been stable no crashes.
Thanks
Kevin
