I think I have neglected mine for so long the wheels are going to be a nightmare to clean.
So in preparation I ordered some Valetpro Blue Gel cleaner.
It looks properly baked on.
Oh and anyone know what pressure washer nozzle will be safe to use, obviously 0 degree is a no no. But what about 15, 25, 40? 150bar.
So guys new car needs a wax it’s Audi ScubaBlue . Just purchased some Auto Glynn High def Wax . Before I apply it what’s the best process before hand . What the best detergent to wash it with ect ? Would you Clay Bar it before hand . Paint is very good car is only three years old 20,000 miles .
I have recently used Gyeon Cancoat. Very easy to apply and there is easily enough to do 2 full coats.
I would only expect 6-9 months from that though, you have to spend a bit more and have a more in depth application process to get 12months-years of protection. So in some sense a good wax will be far more cost effective and perhaps only need reapplication every few months.
In regards to re-applying wax or even ceramic sealant for that matter, when it may be needed, I gather polishing is only required if paintwork is poor state then, I gather a clay bar is good to do beforehand though.
Have a look here for cloths - https://www.in2detailing.co.uk/products/towels-cloths-and-wash-mitts/cloths.html
Lots at various budgets.
Wheel cleaner I would recommend Bilt Hamber Autowheel.
Also I could do with a good solution for streak free windows. I'm really struggling, especially with the windscreen. It's possibly due to using old microfibres that haven't been washed though
... like airbag protocol - usually paranoid about knocking/firing the seatbelt tensioners - but I guess lifting them out is easier on an opentop.Cleaned the engine today and now doing the seats![]()
