- 26 Sep 2017
- In the Masonic Temple
Any 5 series card from 5500m upwards5
5700 or 5700xt?
5700 or 5700xt?
You haven't set up trust so i don't think you canI've an XT if that's any help too you
I haven't seen the comparison of both Gigabyte 5700XT vs 2070S XT (not many games tested though).
Do I need to do this just looked in bios its on auto could this be the problem or is it more likely to be faulty card thanksWas like that myself at start lol have you changed to gen 3 in bios?
Unlikely as you've got a Gen 4 board and GPU, but as with all PC things, never say neverDo I need to do this just looked in bios its on auto could this be the problem or is it more likely to be faulty card thanks
Have you also switched to the other bios on the GPU?Do I need to do this just looked in bios its on auto could this be the problem or is it more likely to be faulty card thanks
No totally forgot about the other bios on it its been a nightmare thinking of switching to the sapphire nitro have you tried yours yet mateHave you also switched to the other bios on the GPU?
Also maybe try re-flashing the stock bios?
Not yet, awaiting a replacement CPU early next week then I can build and get testingNo totally forgot about the other bios on it its been a nightmare thinking of switching to the sapphire nitro have you tried yours yet mats
Think I'd go with the sapphire wouldn't trust another aorus to be honest will try second bios though thanksNot yet, awaiting a replacement CPU early next week then I can build and get testing
Personally if I was you, try the 2nd BIOS and failing that try re-flashing the stock bios, easily downloaded from genuine sites, still no go then send it back and get either the Sapphire or the Aorus?
Ignore, just read back, forget my Aorus recommendation thenThink I'd go with the sapphire wouldn't trust another aorus to be honest will try second bios though thanks
That's what I think maybe a unstable factory overclock
Put old card back in and all's well might get the sapphire nitro this one
https://www.overclockers.co.uk/sapp...ddr6-pci-express-graphics-card-gx-392-sp.html
I'm on the latest driver my old sapphire 260x works fine the thing is its only when gaming it does it black screen for a few seconds noise then pc rebootsDrop gigabyte a message @GIGA-Man . Might be unlucky . I know they can do RMA checks on board and GPU for issues .
Should be straight swap if OCUK test as within 14 days
What GPU driver you on as I know and having issues with RX cards .
Didn't know I had to do that I'm on latest bios on a gigabyte x570 elite and a 3700x with a 750 watt seasonic platinum power supply all brand new a couple of weeks ago and was working fine with old card new card would be ok for a bit then just crash my pc causing it to reboot I didn't daisy chain the power I used to separate leads
Just been in bios and set it to gen 3 see how it goes but I think it's the card to be honest but could be wrongPCI-E 4.0 seems flaky as hell, I'd turn it off.
Thanks yes I did realise the 260x isn't Rnda design but was just letting people know that that one seems to work ok I even did a fresh install hoping something was conflicting but no joy260x isn't RNDA design .
Know people have rolled back drivers for UE4 games
