- 6 Jan 2013
- Rollergirl
I'm having some trouble with resolution due to HDMI cable restrictions, so I'm settled on 1920*1080 120Hz for the time being. What Freesync mode should I be using, basic or ultimate?
Sorry to revive a relatively old thread, but I saw this discussion and I wanted to update you all on the latest developments regarding this TV and Freesync over HDMI.
Samsung recently released a few new firmware updates and now...FINALLY...Freesync works over HDMI with Nvidia's Gsync. I have tested it myself on my RTX 2070 and it works perfectly. As I understand, Freesync will ONLY work with Nvidia cards from the Turing platform and later.
There has been quite a few asking about this recently with your TV, so that's good to know freesync/gsync is working now.
I have the q8dn from the same year and freesync/gsync has been working flawlessly ever since I got my 3080 3 months ago. Worth noting I have to use freesync premium setting on the TV the standard freesync setting doesn't work but premium is the better one anyway.
Poke around with CRU (Custom Resolution Utility). You can add a Freesync/VRR range and see how it does (edit the HDMI 2.1 section). Been messing around with it a few days ago myself, actually had a "funny" interaction. Finally decided to try and fix the otherwise not working VRR + HDR on my TV, turns out the POS (thanks to AMD) does Freesync Premium Pro but is borked and limits the display in HDR to 400 nits peak (out of the usual 1000), turns out the fix is to remove the Freesync range then re-add it, because that way it becomes just Freesync Premium, and voila it works. From what I've seen lots of people that have issues with TVs + Freesync on Nvidia usually fix it through CRU too. 5070 Ti is a bit too new & rare for enough people to run into the same troubles but keep an eye out on topics from avsforums & rtings reviews comments section, could get lucky and someone'll have had the same issue.Old thread I know, but since upgrading from a rtx 4070ti when vrr worked fine on my Samsung Q80T going to a rtx 5070ti vrr no longer works, even when " enable settings for the selected display model" is checked in control panel.
Anyone know of a possible fix?
Disconnecting a HDMI device can reset settings on the TV. Go back into External Device Manager and Game Mode Settings and make sure it's still on. Make sure Input Signal Plus is still turned on. It's pretty annoying. If I ever need to disconnect the PC, I turn the TV off at the wall first.Old thread I know, but since upgrading from a rtx 4070ti when vrr worked fine on my Samsung Q80T going to a rtx 5070ti vrr no longer works, even when " enable settings for the selected display model" is checked in control panel.
