I decided to carry out more tests before committing to further purchases in order to reduce Delta-T. On my setup I have 4x120mm exhaust fans, 3 at top and one on rear. I have 3x120mm pulling inlet fans mounted on the rear of the radiator at the front of the case, and in front of the radiator I have 2x200mm fans in push configuration. The 2x200mm fans are not speed controlled and run at 100%. The 3x120mm inlet/radiator fans are controlled by water temperature sensor. The 4x120mm exhaust fans are controlled by motherboard temp sensor which is a few degrees above case internal air temps. The water pump speed is controlled by the CPU temperature sensor with a 5 second reading interval. For the tests, I ignore the temperature sensors and set the fans so they run at a constant throughout the duration of the test. My approach to the tests was to achieve the lowest Delta-T. I decided to keep the water pump and exhaust fans running at 20% for all tests, only changing the inlet/radiator fan speed in between each individual test, while allowing the system temps to lower back to a starting point of 2 degrees C Delta-T before starting the next test. I ran each test for a minimum of 30 minutes using the Heaven Benchmark and HWinfo64 to obtain recorded readings . At the end of each test I recorded fan speeds, temperatures including ambient, water, Delta-T (calculated), CPU and GPU (average and maximum) and finally noise in dB. I did increments of 10% on the inlet/radiator fans (starting at 30%) and after finding optimal values narrowed it down a bit further with 2% increments but that was unnecessary. So to my results. I found that over all of the tests the Delta-T achieved was between 7 and 13 degrees C. The optimal was with the inlet/radiator fans at 50% (1254rpm). Ambient=27c, Water=34c, Delta-T=7c, CPU=52c (max=56c), GPU=55c (max=59c), Noise=64dB (but I am not sure about noise as that seems high). The Delta-T of 13 degrees C was when fans were at 30% (slowest setting). When the fans were at 60% and 70% the Delta-T was 8 degrees C and the CPU and GPU temps were 1-2 degrees C higher than when at 50%, but the fan noise was starting to get noticeable. The next tests are to determine optimal pump speed to go with that inlet/radiator setting. Its all time consuming, but its fun. Sad me. LOL.
