Hi,
I'm thinking of swapping out some bits for a modest upgrade. The spec i'm going to end up with is
My basket at Overclockers UK:
In addition to that purchase, I have an Gigabyte GeForce GTX 1060 Windforce OC 6GB GDDR5.
I intend to reuse my existing case: https://www.overclockers.co.uk/antec-300-three-hundred-ultimate-gaming-case-black-ca-101-an.html.
Question is, can I use something like this: Cooler Master MasterLiquid ML120L RGB AIO CPU Cooler - 120mm Stock Code HS-07N-CM
I've no experience with these blocks - I would normally put a large air cooler like a Sythe on - but am interested to understand how they are mounted etc. I'll want to OC the 3600.
Any advice would be appreciated. I'm not adverse to getting a new case, but I'm not sure it's necessary.
Thanks.
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £158.99
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-29200C18 3600MHz Dual Channel Kit - Black= £82.99
- 1 x Corsair TX650M 650W 80 Plus Gold Semi Modular Power Supply (CP-9020132-UK)= £89.99
- 1 x MSI B450M Mortar MAX (Socket AM4) DDR4 mATX Motherboard= £89.99
Total: £433.06 (includes shipping: £11.10)
Thanks.
