You mean the Q version ?Sabrent Rocket v1 user here - amazing. Do not buy the new ones they cheaped out when they got popular on the nand.
Those ones are no good for sustained file copy but also I'm lead to believe the existing refreshes of the normal rocket are not what they used to be.You mean the Q version ?
Well for that purpose it would still be perfectIts just to store my Sample libraries on in my studio...So read speeds into Kontakt are important but writes not so much...Once the samples are copied it wont get much write action, just read action...
I was just going to get a 2 TB SSD but figure for the extra 50 and tidyness I would get a NVME....
The Sabrent seems to be the one of the cheapest TLC drives at 2 TB I can find
Well for that purpose it would still be perfect![]()
I get 3440mb read but like I said they changed them to cheaper chips.
And if it's Rocket Q, that's step lower tech QLC Flash drive.Sabrent though with everything the price has gone up since I bought it. Bit of a bummer as I want to pick up the 1tb version as well that’s now over £100.
WD Blue SN550 is right now the best priced TLC drive.
Is that one 3000mb +?WD Blue SN550 is right now the best priced TLC drive.
There's hardly any/only little difference in Windows/game loading times even to "slow" SATA SSD.Is that one 3000mb +?
