I have found the in-game limiter isn't quite accurate and seems to almost range band the fps.
Setting in-game limit anywhere between 130-140 just caps at 144 (monitor refresh). 126-129 caps around 130 and then 120-125 caps at 125.
I noticed this a while back and haven't looked at it much since so new patches may have improved this.
Does he play it on console or PC? I think its console as the movement seems "digital"....
And the kills he get, jeez aims really well....
Could it be some kind of auto assist aiming on console versions?
Console with pad or PC with pad has a built in auto aim. Why i turn off crossplay
If people want to use a pad, then fine but don’t include an aimbot with it!
I tried it on PC (connected ps4 pad) it’s a joke - locks on from the other side of the map like some sort of heat seeking missile
Whaaaat? So you guys are saying that even people using PC and a pad somehow employs some kind of autoaim???
I don't notice any auto aim when using a pad on pc?
On console you need to turn it on IIRC. You can customise it to how you like. It is very very strong tbh. As in it can track through some surfaces.
It's a shame that for warzone you must have cross play enabled. Makes the pc experience a bit a shoddyConsole with pad or PC with pad has a built in auto aim. Why i turn off crossplay
Game is unplayable for me. I cant get through the tutorial without a crash to desktop, no error. If i join a friend i can get into a game but it just crashes out in the same way within minutes.
