Pics please
For Halfords, today:
Get 2 big buckets, ideally with grit guards at the bottom. One for your shampoo, one for rinsing out the sponge. Search for 2 bucket method.
https://www.halfords.com/motoring/c...iars-rg203-5-gallon-yellow-bucket-512829.html - I use these.
- Meguiars gold class shampoo used to be good, but Autoglym or AF are similarly shampoos.
- A couple of plush drying towels.
- Noodle type mit and wheel brush - Both to do the wheels.
Some iron fallout remover.
- Whatever they have in halfords.
Some Bug & Tar remover.
Get a clay bar and some spray lube (if it needs it). Get a quick detailer to use as lube, or use some shampoo and water in a sprayer (cheap garden sprayer).
- Bilt hamber soft clay is decent or whatever halfords has.
https://www.halfords.com/motoring/car-cleaning/clay-bars/farecla-g3-body-prep-clay-mitt-660104.html - The mitt works well!
A polish/glaze (all in one)
https://www.halfords.com/motoring/c...auto-finesse-tripple-polish-500ml-550332.html
Spray sealant.
https://www.halfords.com/motoring/car-cleaning/car-wax/turtle-wax-hybrid-sealant-wax-351462.html
I use Sonax Brilliant Shine Detailer as it's the SHIZ but this TW stuff is supposed to be good!
The above should be your main kit to do a full on clean, decon, clean, polish, seal. I usually do this twice a year, then general washes in between I just do a wash and wipe down with a Spray Sealant.
Detailing is a bottomless rabbit hole, but doesn't need to be full of expensive products and eleventy million steps. I haven't even gone into machine polishing, but the likes of the AF Tripple will clear up a bit of swirling and fill the rest, giving a nice look without using a machine.
For me it's about doing the best you can, getting the best look and protection, for the least amount of time/effort. There's more important things in life than fapping over detailing every sunny day you get.
