I said that at work before the lockdown, shave it to No.1, let it grow, by the time you can come out, it will be the right length.
Honestly I might just shave mines off it's long af and I'm in need of a haircut, It's unsightly.
Lol someone else said the same thinglooks like it ! But actually says "iDeer Life"! What that means I have no clue
For those with clippers if you ever decided to trim certain parts of you anatomy pull the skin tight is it can bloody hurt. Or so I’ve been told.
Good time to try a new hair cut, time for it to grow if it goes bad![]()
Yep, my logic - hardly going anywhere at the moment and won’t be the only idiot with a funky haircut for the next few months.
Used to have a 2 all over but now opt for a 0.5 faded (mid) in to a 2 on top.
Asked the barbers themselves for plenty of tips and watched numerous tutorials, fairly handy generally so shouldn’t be a complete disaster. Didn’t do a bad job with a 0.5, 1 and 2 grades the other week!
Always start lower and move higher. Once it’s gone it’s gone, better to do the cut twice than FUUUUU in the first minute!
Where's the glass from please @Feek?Too many posts without pictures.
Just delivered
The glass was a 'freebie' with the gin, it was from the Drop Store.Where's the glass from please @Feek?
Old one died and is insanely useful so bought another one
I think you got vaseline on the lens mate!![]()
5.11 Rush 72 for when the world ends.
PITA?I have a couple of Rush bags. The little grippy batches on the bottom of the back are a PITA and I had to remove them.
Pain in the ...PITA?
