What upgrades can I do????
30 Mar 2020
Bought a pc the other day,
Specs are
CPU - Intel Xeon e5 1620 v2
Main board - Intel x79
Ram - 8gb ddr3
Graphics - Radeon rx 580
Ssd - kingchuxing 500gb
Not running how I want it to,
what can I do/change to make it run better for gaming?
Thanks
What's your budget?
Your GPU is still a cracking card, is this a gaming machine or other use?
OK, so the GPU will be just aswell as the SSD...
Do you know what PSU you have?
Whats your overall budget, we don't want to spec you something that's out of your price range
I’m a complete novice, this is my first machine. I’m unsure of psu, I’ve been told it’s watercooled. Is there anyway I can find out?
as for budget, i want to do this over time so it’s not really a problem. thanks
Replace the SSD, Add more ram would be the cheapest upgrades. £300 watercooled, I think thats a tad expensive for that spec considering how old it is.
If the system is Watercooled/AIO you'll see all the tubing running from the CPU to a radiator...
It would be good to find out what PSU it has, just incase you replace some parts and it pushes the PSU to far and fails... Its not often the case but you never know with some second hand builds
If you can find out the exact PSU you have, maybe take some pictures of the inside of the machine, it'll help us to know what we're dealing with.
Off the top of my head I'd say the most beneficial/cost effective upgrades would be a hexa core CPU to replace that quad should your motherboard support it and another 8GB of RAM.
I'm hoping your motherboard isn't some random Chinese board.
How do I know what ones to get so that they fit?
Your SSD right now is a SATA one. Replace it with something like this:
My basket at Overclockers UK:
Total: £68.69 (includes shipping: £8.70)​
Use a cloning piece of software to transfer the OS from the old to the new. Macrium reflect is solid enough to do the job. There is software to scan your PC for make & speed of RAM, CPU-Z will tell you.
I have asked the person I bought it off
Ah okay, like i said previously I am new to this and was going off some advice of a friend. He said it was a good deal
Yes there is pipes. I’m trying to upload a picture it won’t let me
