- 12 Feb 2014
- Somewhere Only We Know
I've got a B450 has anyone any ideas. Can match system fans to CPU, or System or Chipset. Anyone any good settings in bios for the four temps and speeds.
In the bios > Advanced Mode (F7 if your not already in Adv. Mode) on the right of the screen there is a hidden menu that pops out when you move the mouse over to it, select hardware monitor, you can adjust all of your fan curves in there, you can select for each fan which temp you want it to ramp up and down with, ie CPU, Chipset etc, select the fan at the top of the screen you want to adjust, now on the left youll see the option to select what temp you want the fan to run with, make sure to select the smart fan tick box, adjust the curve accordingly.
As im water cooling I have all of my radiator fans connected to the CPU fan header via a basic fan controller which supplies power to the fans via an SATA connector, the CPU fan header just supplies the PWM signal side of things, im running AMD RyZen, the temps even at idle seem to jump around a bit, so I have 0oC = 42%, 60oC = 42%, this keeps my fans running at around 800rpm all the way up to 60oC on the CPU, this also keeps them completely quite, then the next step up is 70oC = 75% and then finally 80oC = 100%, works perfectly fine for me, this is just a guideline and you may have to tinker with those yourself for what suits your system best.
