you cant browse a shop anymore ? is that because CV-19 or the new Halfords way?
Looking for suggestions about my wheels. Because I'm a lazy sod I've been running aggressive track pads since January and the brake dust has really eaten into the rim, clay and Iron X is barely scratching the surface! Been looking at Bilt Hamber wheel cleaner as it seems to be the product everyone raves about at the moment; Do people think this may help move what's stuck to my wheels?
It has been an embarrassingly long time since I gave the Subaru a decent clean, and I need the below:
Without me trawling through this thread I can think of Autobrite, Cleanyourcar, and Slim's detailing. Anywhere else I should be looking for a small order with delivery? My local "Birmingham Detailing Shop" is closed due to Corona, no deliveries, collections, nadda.
- New wash mitt
- Shampoo
- Wheel cleaner
- Maybe clay bar
Thanks.
Minimal effort would probably be a refurb of the wheels and get them to blast/de-coat then plate/paint the bolts. As above you'll struggle to do anything to them without touching the wheel itself..
Got some born slippy clay lube and car pro reset shampoo delivered today, I just need a smaller disc plate and pad to polish the small parts of my car now.
Those that have used the CarPro reset shampoo how much do you put into a bucket of water, I see it mentions 40ml on the directions but just wondered if you use less?
I use 35ml. Put in the bucket of warm water then blast it with the pressure washer for mixing + thick velvety studs.
Thanks, I’ve used dodo juice born to be mild shampoo for ages now, but was keen to try something else and the CarPro reset said it’s ideal for cars with ceramic coating.
- New wash mitt
- Shampoo
- Wheel cleaner
- Maybe clay bar
Thanks.
