Upgrading to 144Hz. do my fps have to match?
28 Sep 2003
London
if i want to upgrade to a 144Hz monitor does that mean i need to have my fps at 144 too?
im currently getting between 60-90 fps, would i see a benefit from a better monitor?
also, is it a noticable upgrade or not really?
No, your frames don't need to match and you'll see a very noticeable difference going from 60Hz to 144Hz.
60 to 144hz is the best monitor upgrade you can make for gaming. The increased hz will make your gaming better even if you can't hit 144hz, by reducing tearing. Plus Windows in general will be a more pleasant experience. A 2060 compliant 144hz Freesync monitor will improve things even more.
It doesn't have to be a GSync monitor as it can also be Freesync as long as it's GSync compatible as well. If you want to go ultrawide you could go for the LG 34GL750 which will complement you card very nicely. https://www.overclockers.co.uk/lg-3...ble-curved-widescreen-led-gami-mo-156-lg.html.
Out of stock here but should be available elsewhere. Whatever happens you will need a variable refresh rate monitor otherwise you frame rate will not sync with the monitor and your games will be a jittering mess.
I recently bought this Gigabyte 1440p 165hz screen
https://www.overclockers.co.uk/giga...ync-led-backlit-gaming-monitor-mo-004-gi.html
I have previously been gaming on a 4k screen at 1440p 60hz as my GPU cant handle 4k
At 165hz 1440p there is a big improvement, especially in CSGO where the FPS is locked at 165.
However getting 165fps at 1440 on my Vega56 isnt going to be possible in newer games.
What I found most surprising was how effective freesync is at lower FPS.
In RDR2 I was getting 50-70 fps on my old 60hz screen. It was perfectly playable but the new screen at the same settings with freesync is much smoother even at those lower FPS.
Freesync was a much more significant upgrade than I expected it to be.
I would have bought the LG GL850 but I got tired of waiting for stock.
I prefer the pixel density of 1440p at 27" is pretty good
IT makes me sad not getting 165 fps in games when i have a 165hz monitor...
hz does not equal fps its a common misconception. Its not the same thing at all. You cant "hit 144hz" your monitor is 144hz, static, it doesnt change. FPS changes dependent upon variables such as speed of your machine, speed of graphics card. HZ is the refresh rate of the monitor its static. Faster refresh produces a smoother picture.
Hence why I can run an old 3dMark 2006 benchmark and hit 500+FPS on a 75mhz 1440p Monitor.
They are not the same, however in these cases they are intrinsically linked. You will get 500+ fps sure, but your monitor will only be able to draw at a frequency(hz) of 1 frame every 1/75th of a second, therefore anything above 75fps you won't see.
True they are linked but still people think 144fps is the same as 144hz and its not. If you think of hz as fixed and fps is variable it tends to make you understand they are two different quantities. For instance going from a GTX 1060 to a RTX 2080 is not going to improve your "hz" but will improve your "fps".
