MacBook Pro - black lines on bottom of screen... UK consumer law?
Caporegime
29 Jan 2008
Hey guys, I'm in the slightly frustrating position of having some issues with my MacBook Pro just after Apple Care has run out (not that I could leave the house at the mo to get it fixed regardless)...
Annoyingly I purchased Dec 2016 so my Apple Care policy ran out just over 3 months ago at the end of Dec 2019.
These horizontal, thin, black lines appear across the whole width of the screen from the base to about 1.5 cm above the base. They appear intermittently - they're not there at the moment.
Is this generally a heat/component issue or a connection issue? Anyone else had this and did it get progressively worse or is it just a nuisance to put up with until able to get it fixed/lockdown over?
Secondly - I don't think it is appropriate for a laptop to start to get an issue like that at 3 years 3 months - despite being just out of Apple Care does anyone know whether this sort of thing has been covered regardless under UK consumer law? (I'm going to do my own research here too but useful if someone else knows/or has dealt with apple before on something outside of apple care and how much back and forth you needed before you got them to deal with it.)
Lastly - I presume as stores closed they're not likely to be able to fix any time soon - or has someone been able to get a courier pick up for a faulty Mac? (Presumably they're more likely to do this with Apple Care than someone citing consumer law etc..)
Lastly - slightly minor issue but the "E" key on the keyboard got a bit loose and has now come off - hopefully that is something they should fix too given the age, expected longevity of this sort of product. Annoying I perhaps should have had the battery looked at too before Dec but meh...
Have got a backup Dell laptop too so can go without for a bit if needed.
13 Jul 2005
Norfolk, South Scotland
You have a right to have the fault remedied for the reasonable working life of the product. I would say that's probably somewhere between 5 and 10 years on a good spec Apple laptop. You've got a nailed-on case as long as you can prove the defect was present at the point of manufacture.
And there's the rub. To claim under the regulations currently in force after 6 months you need to prove that the fault was present at the time of manufacture.
If you can find dozens of similar issues reported on MacBook Pro's then you'll likely get a repair. Otherwise not.
Those laptops still have a fair value to them. Personally I would accept that stuff breaks and pay for the repair.
24 Jun 2008
Policy used to be 2 years in store, no CL claims via apple care, anything after 2 years needs to be done through official (read: legal) channels.
not sure how it works due to Covid19 at the moment but all the best
10 Apr 2013
I'd just take it into the store, I've had stuff like this happen in the past and they've sorted it anyway. One of the good things about Apple.
I'd give this a try when the store re-opens. I've no personal experience but I've heard friends who have taken back Macbooks out of warranty and had them repaired for free. I think when you spend several thousand on a laptop there's an expectation it'll last longer than 3 years so hopefully they'll offer you some level of support to repair it or at least discount the repair.
Caporegime
OP
29 Jan 2008
No consumer law claims, sorry
Ah no worries, cheers.
Indeed - I dropped nearly a couple of grand on this thing, I'd not expect to replace it for another year or two yet (and frankly would still expect it to be working then albeit just dated relative to what is available). If they release a 14 inch MBP I'd be tempted in a year or two but would expect this to still be working and useable as a backup or for travelling. I mean my Dell is like 6 years old+ and still pretty snappy when running linux mint, fine for programming, web browsing etc... (16GB or RAM, old i5 processor and 256GB SSD - still perfectly usable (obvs screen is a big downgrade), decent case and Dell laptops tend to be pretty robust).
Looking back at this I've gotta say thank you for posting that as, though it is almost the opposite of what I described in the OP (vertical light areas instead of horizontal back lines) it does actually seem to be related and I can now see that issue - am not getting the black lines at the mo:
So on that basis (4 years) it seems my screen is allowed a free repair under the above program... also the keyboard issue under this one:
Looking at known issues I guess the keyboard issue might be fixable for up to 4 years:
https://support.apple.com/en-gb/keyboard-service-program-for-mac-notebooks
I'll give Apple a try and see what the deal is under lockdown... then again no big rush - so long as stores open again at some point within next 9 months!
25 Jun 2006
Got a pic of the whole screen? Are you talking about the black areas near the icons on the dock? If yes, then that would be covered under Apple repair program mentioned above. It's caused by the screen cable overstretching.
50 million edits later (I kept reading it back to myself and not being happy): If you're talking about the black thin lines which are near the white thick faded line, then that looks like the Display is damaged. This could have been caused by either the display itself taking a knock or the the Display Cable/Display header on the logicboard being damaged (which would explain it being intermittent). These wouldn't be covered under a repair program and you might have trouble claiming on consumer law. Apple have a set of visual guidelines they compare against which they use to determine what is elligible or not and if it looks like accidental damage they will probably deny.
Caporegime
OP
29 Jan 2008
Yep :)
Nah the display isn't damaged (re: the black lines), it's either some connection or overheating issue. I think you misread my post you just quoted - the black lines issue is not there in the photo I posted (it is intermittent), I posted the picture to show the issue the poster I'd quoted referred to - the vertical lighter and darker areas showing in the image.
Not quite sure what you're referring to seeing there - either a reflection or the OCUK forum layout which includes black and white lines. I'll try and take a photo of the black lines next time they occur.
25 Jun 2006
Yep :)
Ahh ok, yea I did mis-read your post apologies, you quite clearly said 'am not getting black lines at the mo'!
Now that you told me your screenie is good old Ocuk I can see it now. I've used a black theme on Ocuk for so long I didn't think about Ocuk and thought the lighter blue bit was damage and the shadows on edge was the black lines :) That's why I were asking for a whole screen pic as I wasn't sure I was seeing it properly. The issue I thought you were describing is something we see a lot from knocked screens etc which start off as thin lines and worsen over time, and if this was the case Apple wouldn't honour the repair program problem even if it was obviously a separate issue as the same part has 'accidental damage'.
You should be fine then, you will be covered for the stage-lighting type issue by the repair extension program so wont need to worry about the consumer law.
