- 9 Dec 2009
- Bristol
Hi all
After what must be nigh on 10 years my Corsair TX850 is starting to fail. I want to limit spending to around £100 if at all possible, is the one below ok?
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020195-uk-ca-24s-cs.html
Also forgive my daft question (it's been a while since I bought a PSU) but does a fully modular PSU come with cables? There's nothing in the pictures in the shop and I'm unsure if the connectors referred to in the spec are just the connection ports on the unit or physical cables.
And one last question, my 2500k system (see sig) is struggling on newer games so a platform upgrade is imminent with pretty much everything needing renewing (though I'll keep the SSDs and case), will this new PSU be up to the job running an upper-range Ryzen system with a decent GPU, several storage drives and a few peripherals?
Thanks
Thanks
