Hi All
I am wanting to replace my Sennheiser PC360. I had the GAME ONE before, but my now wife, hoovered the cable a few years ago before crying. with some better headphones+modmic. I have been doing plenty research but keep going round in circles.
Looking to get v moda boom pro or modmic 4, due to cost. Keeping it below £60 for a mic instead of a blue yeti. The cheap usb desk mic's, without arm seem to have a lot of feedback but its only the modmic 4 which has unidirectional mic option out of these but also has omni.
For headphones, I want mainly for gaming, audio fidelity competitive fps mainly footstep pinpointing and general use. Comfort is important to me since I have a slightly bigger head than normal.
My research says I need treble, imaging and sound-stage to achieve this.
I do like open back since it's what I'm used too.
I have narrowed down to these headphones
- Philips SHP9500 £110
- AKG702 £110
- DT 990 EDITION £130-140 32/250 ohm
- Audio Technica AD500X £122
- Sennheiser HD 599 £122 - kind of want to try another brand but these are too comfy
I'm not wanting to spend more than £140-150ish on the headphones, closer to £100 the better.
If I get 1 of the above with the modmic. I am seeing that I will need a headphone dac+amp? But I want a budget one for around £50-60ish ideally.
I am told that I need separate input into the dac/amp for mic due to the modmic, not a combined one like the SB G1 with just 1 hole for both which is for a gaming headset.
I'm looking at:
- SoundBlaster G3 - https://uk.creative.com/p/sound-blaster/sound-blaster-g3 £50
Is there anything better for under £60 out there, do I really need to push for SB X3 or SBX G6?
I have been looking at headphones reddit -
https://sites.google.com/view/headphoneadvice/gaming/category-100-400 this is Reddit's advice for $100-400 for gaming but it seem's outdated, especially on the AMP recommendations.
BACKUP no hassle all in ones. Both closed back though.
- Logitech Gaming Pro X £90 (staff discount at currys)
- HyperX Cloud Alpha S £90 (staff discount at currys)
I have Asus HERO VI for my 4th gen i7 with SupremeFX on board sound so it was pretty high end at the time.
If anyone can advise me for any headphones or any amp recommendations on my requirements that would be great. Thank you in advance.
- AKG702 £110
I'm looking at:
. I want to try the v boom pro first if I don't like it send it back before ordering for double the price. Just need to wait for stock.
I like Zeos. He knows his stuff although his reviews are a mess and he clearly can't be bothered to fact-check things. His review of the X7 was shocking. He talked about sound quality for all of a few seconds - 40mins in, couldn't be bothered to try the Windows Driver package and compared SBX to just equalisation - something you can adjust in with the equaliser. It's interesting because for a long-time he has hated 'gamer' products yet gave glowing reviews of the Hyper X Alphas and Coolermaster MH751/752s (both Takstar rebrands). So I think you just have to be careful with some of his recommendations particularly if you're coming at this for an angle where you want something for gaming.
