Haha!
Did you also go for the funky matching, albeit expensive grit guard?
Yes, Yes I did.
It needed to have something over my trusty black £5 bucket in addition to the colour to make me justify it......![]()
I got this snow foam lance and it’s been superb,used it against a karcher one and my one was so much better.Hello guys
Looking for a cheap snow foam attachment for my Karcher pressure washer + snow foam shampoo as well. Would something like this do the trick or should I look at spending more?
https://smile.amazon.co.uk/KKmoon-Pressure-Thickness-Adjustable-Portable/dp/B07VNMLRW2/ref=sr_1_10?dchild=1&keywords=snow+foam+karcher&qid=1586767037&refinements=p_76:419158031&rnid=419157031&rps=1&sr=8-10
https://smile.amazon.co.uk/Autoglym...words=snow+foam+karcher&qid=1586766716&sr=8-3
I’ve heard the Argos polisher is actually really really good compared with the das 6,sometimes it’s not the machine but the process and products you use.Looks like lots of other people have been thinking the same as me, every where i look DAS 6 pro's and pro plus's are out of stock. Will have to check again at the end of the week.
I was wondering if anyone can help me out with the dilution ratio of Polar Seal, I've tried Googling but can't seem to find the answer.
Although I have a pressure washer, I thought it might just be easier using the hand pump foam sprayer that I have.
Now they say using a pressure washer to mix 40ml of product with at least 200ml of water. What sort of dilution would be somewhat equivalent in the pump sprayer?
Hi,
Autoglym recommended not to use it this way as it is designed for a foam lance.
https://www.detailingworld.co.uk/forum/showthread.php?t=415820
And for those using Bilt Hamber Auto Foam, what ratio's are people using for lances (1ltr lance here)?
I saw somewhere mention 600ml of water to 400ml of product which seems a bit excessive (2.5:1 if my maths is correct) and expensive compared to others which seem to typically be 10/20:1 (waterroduct)
For the BH snow foam I generally have about 150-200ml in my 1L foam bottle, and top it up with hot(ish) water. I've never had an issue with the consistency of the foam production and it does what it is supposed to!
It’s not about the consistency of the foam, it’s about the amount of product on the panel and it’s effectiveness.
Hi could someone please advise me on how to wash the following after use?
1) https://www.halfords.com/motoring/c...er-thick-microfibre-car-wash-mitt-232934.html - My wash mit, relativly clean
2) https://www.halfords.com/motoring/c...guiars-supreme-shine-drying-towel-560869.html - My drying towel which is free of dity (because car was clean!) but is full of this wax: https://www.halfords.com/motoring/car-cleaning/car-wax/meguiars-hybrid-ceramic-wax-768ml-836624.html !
I rinse my mitt out in the wash bucket after finishing the wash phase, then wring it out and leave to dry.
All microfibres go in the wash with a non-bio detergent and depending on the weather tumble dried or on the washing line. No fabric softener is key. You can buy dedicated microfibre detergent but never found a need. I use fairy non-bio powder.
