 - 21 Apr 2020
Hi Overclockers!
Now I am in desperate need of your help, I keep having this issue with my pc (See links at the bottom). Every week or so my PC will get stuck in a loop where it thinks there is new hardware in my machine even though nothing has changed. This will loop for a while before I can get it to boot, entering the bios will show even more strangeness for example detecting both 8gb sticks but only displaying a total of 8gb RAM or detecting a single stick but showing a total of 16gb. Now this will happen with XMP enabled or disabled.
So far, the trouble shooting I have done is send my Motherboard, RAM, and CPU to be tested; they call came back with no issues found (Motherboard and RAM tested by Overclockers, CPU Tested by Scan Computers). My GPU has been used in an Intel system and has zero issues, so I suspect this is not causing any issues. I also purchased a PSU tester to make sure that does not have any issues, again that is fine. I have also tried changing CMOS battery (though it was the one from my old i7 build so quite an old one) but the problem still persists.
Please see the two-video links to show the issues and the imgur album, please I will happily take any advice right now.
PC Specs
AMD 3900x Stock
MSI MEG X570 ACE
AMD 5700xt Red Devil
16gb (2x8gb) 3600Mhz Corsair Vengeance (Ryzen Tuned)
EVGA GQ 850w
1tg Sandisk SSD
1tb Seagate HDD
2x 500gb WD HDD
https://imgur.com/a/EUzVXwq
PC Specs
AMD 3900x Stock
MSI MEG X570 ACE
EVGA GQ 850w
1tg Sandisk SSD
1tb Seagate HDD
2x 500gb WD HDD
