guess ill be drunk and pip you to the post
sapphire pulse 5700 and a load of cat 5 cables for my consoles hanging down![]()
Welcome and on TROH.
The Roll of Honour.
I have a feeling that it will come up with that when flashing but you can force it to overwrite, that's what the old cards years ago last time I flashed used to do, but obviously it's risky as it anything like that.And another resurrection.
Running really well now so not in a rush to undervolt/overclock yet.
Did try the XT bios flash though, but came back with "Subsystem ID Mismatch" or something like that.
Exactly it's even the reference card you couldn't get a better match tbh. Good luck and let us know how it goes if you force flash it. it might be worth thinking though, have you got a spare card i.e. think of worst case, you brick it and it won't take it, you can flash from another card onto this one if you put a 2nd card in the machine so that way at least you can get your original BIOS back. Also, use GPUZ and backup your current BIOS so you've got that backup!Been reading about the forced flash, but only used GUI programs before on Nvidia and was hoping AMD would just work the same. Will probably try it some time though as i keep reading this GPU is perfect for the XT bios.
Thread resurrection..!
Doesn't seem like this is a very popular card on here but here is mine. Got it as a discounted B grade
I've undervolted it by 100mV and the card happily runs at stock speeds but produces less heat and therefore runs quieter.
Average power consumption during load 115W.
Also modded the BIOS so that at idle fans run at a whisper quiet 700rpm.
Got it done. Easier than i imagined.
you're running PCIE1.1 there mate get that changed
weird that you have more shaders than a genuine 5700XT lol
God I must've been tired when I posted that jhahahahaIs the PCI-E1.1 not a power saving feature? When the GPU is put under any load it does go to PCI-E3.0.
You have 256 more than me.![]()
Mmmm, possibly, mine have never shown that in all the years I've had an AMD, always show 3.0Is the PCI-E1.1 not a power saving feature? When the GPU is put under any load it does go to PCI-E3.0.
Yeah mate always hit and miss tbh... some it works some it looks like it and doesn't... looks like you're the latter. However, still a great card and as long as it's reliable, just find out what your core and memory clocks can be put to and enjoyWell i am back to 5700 none XT.
Tried a few games and was just crashing and freezing. Think it may be Drivers though as when/if it crashes to desktop, i can't open AMD Control panel.
Flashed back to original bios and all is fine again.
