I had plenty of crashes on my Xbox 360 :/
Also weren't they pretty famous for dying completely?
Yeah the early 360 models had an issue.
That's why the Xbox One had much better cooling. And Series X looks to be even more advanced, hence the tower design.
But then you have to tolerate the annoying noise of small, high RPM fans.
The Xbox One had a single 110mm fan IIRC.
I remember when Halo 3 (I think?) came out and the instant update required resulted in a number of consoles getting the RROD, I knew about it and still installed the update and...yeh console went off to MSRed ring of death. I had that one 2 Xboxes and binned them after attempting repair
Yea which is still quite loud at high load. 110mm isn't a large fan, that's smaller than standard case fans and I'm guessing they don't exactly use Noctua ones...
According to the graph, it will have been around launch. I would imagine within a few months NVIDIA will have released a new GPU that was significantly more powerful than a 360.
Xbox 360 was loud, jesus sounded like it was about take off with the disc drive spinning and as said had those really annoying high pitched fans when playing a downloaded game. The PS4 Pro is a mix of nice and quiet to suddenly sounding like vacuum cleaner when it starts to heat up but better than previous generations.
I've read that the One X is very quiet so hopefully both the new Xbox and PS5 will use quiet cooling systems.
