- 21 Dec 2019
- Planet Thanet
So you guys probably know
If you have to reinstall windows it does not actually take that long
It's all the other software, drivers, settings, themes, updates etc that takes the time
This gives you a windows install usb that has all your other stuff on it
It gets installed along with windows
While you go have coffee
Or a smoke break etc.
This post will be a bit long so if you aren't interested by this point walk
Away now lol
It actually takes me less time to do this than to type it out lol
REQUIREMENTS
Windows install usb which is a minimum of 16gb the larger the better
If your Windows installed is 40gb it should just fit 16gb USB due to this highly compressing it
Windows installed of approx 80~90gb
Will just about fit 64gb USB drive
If your Windows installed is huge unless you have 128gb or 256gb USB flash drive no point reading past here
A second drive to store the wim file
Internal, external, flash drive 16gb+
So if still with me
Here we go
Boot off your Windows install usb
As soon as you get screen with pick
Language, region etc
Press shift + f10
This opens an elevated command prompt ~you can't do this by using repair my pc and then cmd
You need to know drive letter to store wim file~it can't be C if Windows is installed on C
If you are not sure use Diskpart
Then type list disks to figure it out
Edit~Thx @tnx for suggestion can also type list volume to further help find where to store it
In this example the wim will be stored on D
Type exactly this, spacing must be totally correct
Dism /capture-image /imagefile:“d:\mycustom.wim" /capturedir:c:\ /name:mycustom
WARNING
May be hard to tell where the spaces are due to my phone not letting me do the command all in one line
Will finish the post anyway and see
If can amend it on pc tomorrow
If done command correctly after approx a minute
You will get a % progress counter
Once it's 100% type exit
Then press cancel windows install
Restart pc and find the
mycustom.wim file wherever you stored it
Rename it to install.wim
Copy it and browse to your Windows install usb then to the sources folder
Paste it in there say yes to replacing
The existing file
Job done.
Now when you install windows all your stuff will be there too.
Though this post is long it took me under 10 minutes to actually do this
3am so will try to sort out the command prompt spacing
Tomorrow on pc
But after capture-image 1 space
After mycustom.wim 1 space
Between \ / there's 1 space
None of this is destructive to what's on your pc if done as said
Until you actually use the completed usb to install windows
Thanks for making it to the end of this post if you did.
Hope this proves useful it's saved me hours when reinstalling Windows
Ps if I made any mistakes don't shout at me I will sort them tomorrow.
Away now lol
REQUIREMENTS
So if still with me
Here we go
Press shift + f10
WARNING
The existing file
Job done.
Tomorrow on pc
