I bought the above ram for my 2700x build last May, and I've never been able to get it to run stable at anything above 2133MHz, and even then i suspected the BSOD's i got were ram related. I needed my pc so couldn't spend more time trying to sort the issue at the time.
Fast forward to December and I bought a second 16GB of the same ram. And from that point ive had nothing but stabilty problems. Finally this week ive been able to spend some serious time trouble shooting. including swapping out the motherboard and SSD.
So, the original 16GB can work alone or with the 2nd pack at a fairly unstable 2133MHz and nothing beyond that. The 2nd pack works as id expect them to, I've had them easily running stable at 3333MHz
Switch them out though on the same settings with the first pack and the pc won't even put out a signal to the monitor.
Faulty ram? Or something I'm missing?
Thanks in advance for your input.
