OK, i'm going to offer the following advice, but you will have to follow it to the letter.
If at any time in the past you have had or still have Ryzen Master installed, first thing is to uninstall it. Download the latest bios for the CH8 and save it to a usb stick making shure you re-name it as usual. Once Ryzen master is uninstalled, re-boot back to windows and make sure there are no leftover apps still installed from Ryzen Master, if there is, uninstall them re-boot and check again. Assuming all is clear and you already know all of your safe ram settings, re-start and boot to bios. Exit, load optomized defaults, save and exit.
Insert the usb stick in the BIOS FLASHBACK port and do a bios flashback.
Boot to the bios and input all your ram settings, voltage, SOC voltage, cLDO VDDG voltage, cLDO VDDP voltage and any other voltages that you had ram related.
save, exit back to bios.
This now the important bit, although so was getting shot of Ryzen Master.
Boot to bios/tweaker/Performance Enhancer and set Level 3 oveclock/ back to External Digi+Power/Cpu to LLC3/cpu current capability to 140% (yes it will be red, ignore it)
Now down to PBO/PBO limits to Manual/PPT limit to 0/TDC limit to 0/EDC limit to 1/ Precision boost clock overdrive to 200mhz/save and exit................back to bios and move to Advanced and drill your way down to XFR and accept it, than set the same settings as PBO...................boot back to windows. Now, tell me you are seeing the same result ?
