being announced next month at gtc
Remember that last time around Nvidia pulled a switcheroo and the much-anticipated Volta was a data-centre part and they launched Turing as the consumer part.
That's good then.
I already pimped out my gaming HTPC with an 3950x, 32gb RAM and 1TB Samsung Evo Plus, using a 2070s as an stop gap.
I have £1500 saved the for 3080ti, so if it turns out to be that price then my wallet is ready!
Get ready to be reamed for £1500.
Which games? I mean with any game, you kind of have to be sensible with settings. Toggle on RTX or hairworks or some ridiculously intensive process which does very little and it can cause any GPU a few issues.
If you're insistent on going ultra on every single game.. then sure.. as with any other gen.. for that you'll need the top of the line card.
My RTX 2080 has troubled me with two games; KCD and RDR2. With setting optimisation, RDR2 got very very playable.
I imagine an RTX 2080 equivalent GPU in a console can easily power games to 60fps given they can optimise better and consoles normally hover around the low to medium settings territory for graphics.
Try running RDR 2 at 4k on that 780ti in native resolution.
I play on triple 1080p screens for a while as well (as I prefer the larger FoV and can always fall back on a single 1080p when performance is not enough or the game doesn't support multi displays), and that's about 75% of 4k. There are quite a lot of new and relatively older games that require tweaking to various degrees to keep it stable at 60fps - that means no dropping into 50pfs or even lower, no 50 to 70fps and call it a 60. And no, no "dirty" hairworks (aka The Witcher 3) or RT of any kind. For instance, RDR 2 has the majority of the settings to low or disabled. Never mind "medium" across the board as it would deep constantly into 50fps (and perhaps lower).
Anthem, Crysis 3, Deus Ex MD, Just Cause 4, Kingdom Come Deliverance (if I remember exactly), Metro Exodus (without RT), Tom Clancy's The Division 2 (and the 1st one I think), Watch Dogs 2, Quantum Break (I think) are just some that require various adjustments - some minor, some important (as in "it bothers me that I have to lower settings that much or is noticeable). Increase even more the resolution to 4k and the drop will be more significant where it would probably bother me a lot.
Sure, each to their own, some won't mind 30-40fps or even lower - after all, there are millions of people playing games that go into 20fps and don't have the best image quality (plenty example on consoles), or just drop settings as low as needed, ergo wanting constant 60fps at relatively high settings (not maximum, mind you!), may be seen as... ridiculous?Still, in my book, if is X resolution at Y fps, then that Y fps has to be maintained and frame rates should not drop lower. Everything else is just marketing.
Can the next consoles do 4k@60FPS now, at native resolution? Sure, for most part should be no problem, but in the future... well, that's another story.
In future it maybe an idea to read the last couple of pages of a thread before posting.Nvidia are announcing something on 14 May. Let's hope it's not a 20x0 Super-Duper announcement like the last time.
Could you imagine the Heart attack AMD would have if Nvidia released there new cards at these prices
3070 £200
3080 £300
3080ti £500
It's good to have options, but not if every one of them is overpriced.Why do they even need so many increments of pricing?
Produce a £200 good enough card for most gaming and then produce a £600 top of range card and thats it.
20 months between 970 and 1070, then about 30 months between 1070 and 2070. Even September this year is still only 24 months.
Autumn 2016 release for RX 400 series cards, followed only in April 2017 for the RX500 series cards, so only about 8 months.
Then Vega in August 2017, and Radeon VII in February 2019, again each of those only 6 to 8 months apart.
Then RX5700 series in July 2019 only 5 to 6 months after Radeon VII.
We're overdue an AMD release by now, its been over 10 months since the RX5700 series. Not really overdue an NVIDIA release yet.
I didn't go back far enough apparently!In future it maybe an idea to read the last couple of pages of a thread before posting.![]()
There needs to a fair range to choose from to cover so many different monitor resolutions & refresh ratesWhy do they even need so many increments of pricing?
for example
1080p 60hz
1440p 120hz
4K 120hz
Plus say the 1440 120hz person can't afford spend £600 but can afford £300 to £400
