Man of Honour
- 13 Nov 2009
- Northampton
The big issue as exactly the octane rating pertains to is knock, if you put 95 in a car designed for higher it could have uncontrollable knock and the engine could be seriously damaged.
If its preferred rather than required then it will have the capability to regulate itself properly with the lower standard.
My car is tuned for higher octane and while it could just be my engine my valves and pistons were noted to be very clean, I've only run it on 99.
Not strictly true. While an engine will knock when run on a fuel with insufficient knock resistance (Octane) ECUs for at least 20 years have utilised closed loop ignition sensors and will retard the ignition when knock is detected and in some cases introduce more fuel.
We are now at a stage where they also model ignition efficiency and can target increased cylinder fill (Boost) to deliver the target torque in a knock limited situation where possible
