Thanks.Its not worth swapping unless you need RTX.
Depends. There are some games now where it actually makes a big difference to visual quality. Metro Exodus and Wolfenstein Youngblood for example. What's far more interesting in terms of RTX features is the new DLSS though, which is genuinely impressive to the point that it's preferable over native resolution in Control and Wolfenstein Youngblood. You also get the more minor Turing benefits like integer scaling and VRS, plus the 2080 is a little faster than the 1080 Ti and uses a bit less power. Of course, the trade-off for all this is the VRAM. It remains to be seen how 8GB will hold up with next-gen titles. I certainly expect it to become the new minimum at least.Does anyone ‘need’ RTX? It’s not even noticable yet, at least in a couple of the games that use it
In any case, I probably wouldn't bother swapping a 1080 Ti for a 2080 at this point, with Nvidia teasing Ampere. If the past couple of generations are any indicator, the 3060 should offer 2080 performance at a much lower price point, with ongoing driver support and likely improvements to RTX performance.
How does a 2080 (non Super) 8GB compare to a 1080Ti for 3440 x 1440 res?
I can't find any comparisons of the 2080 8GB maybe because its EOL
Cards are
EVGA 2080 8GB FTW3 ULTRA GAMING Turing
EVGA 1080 11GB Ti SC Black Edition GAMING
RTX only, as it uses the tensor cores.Is DLSS only for RTX cards? Or is it supported on GTX cards too?
What if the two cards are the same price, which would you pick for 4k / 3440x1440?
Cards are
Really, even with the 3GB VRAM drop. I’ve found a few comparisons now of both with games and benchmarks and the 1080Ti is still better - quite a lot better in some testsIf that's your question, then the 2080 is the better choice.
AS for "needing RTX" well some of those RTX features like Variable Rate Shading, Mesh Shaders, Sampler feedback and Ray Tracing that are coming to consoles and AMD cards in the form of Directx 12 ultimate.
RTX also includes DLSS, which was just released last month and is DLSS done right.
Then there is VRSS for VR, which works really well.
I wouldn't buy a 1080ti over a 2080.
Edit, remember it’s not the super. Just 2080 8GB
Thanks all
Thanks all
If you're getting the 2080 for a net spend of 0, then do it because its a no brainer.
However if you're having to spend money out of your own pocket, I'd be waiting for the 3xxx series release.
2080 is the faster card now. With drivers, thats been put to bed IMO. I know some early benches showed the 1080ti potentially pulling ahead in a few titles before. Also Ray tracing and especially DLSS 2.0 might end up being a almost unfairly good feature in some games.
What happens at 3.5 / 4k with AA when VRAM runs out out the 8GB 2080?
