- 22 Sep 2008
- Burscough
I've already got a job!
I'd just like the ITER work!
No, I’m not confusing the two. Note I said we already have fission reactors and have for some time. I don’t see it happening any time soon. Point is if you get commercial fusion reactors that in itself would be an awesome achievement - we have electric cars etc... I suspect any mini fusion reactors would be a lot further off and the main benefit from fusion reactors would be just getting very cheap electricity on the grid (eventually) - obvs there are initial infrastructure costs etc... How feasible, how desirable and how costly a mini fusion reactor is is another matter, especially when electric cars, battery technology, availability of fast charging stations etc.. is improving.
I am somewhat dubious of the claims made in the article. The video is very good though, although at the very start he repeats a few common tropes about seawater being the fuel for fusion and that fusion is "clean". I work at ITER, so have a vague idea of the state of things...
Fusion is not exactly fuelled by sea-water. He is referring to Deuterium-Tritium fusion reactions. It is true that deuterium can be extracted from seawater, but the other isotope of hydrogen required, tritium, is only available in trace amounts in the environment and is a fast decaying radio-isotope (half-life 12.3yrs). There is only ~3.5kg of tritium naturally available at any one time on the planet. Instead, the required tritium must be bred inside fission or fusion reactors by neutron activation of lithium. [..]
There is one situation I can think of in which a practical fusion reactor much smaller than a power station would be very useful - bulk transport ships. More a midi fusion reactor than a mini fusion reactor. Much more feasible than one small enough to be the engine in a car, both in terms of existing at all and in terms of the cost of such a thing. If you're paying $100M for a vehicle and it uses $70K per day in fuel alone, paying a lot more for an engine that has a miniscule fraction of the running costs is definitely worth it on cost alone. You'd make the extra engine cost back in reduced fuel costs alone in a very attractive period of time but that's not the only cost saving. You'd also be able to run your transport ships at a higher speed (current container ships are speed restricted to reduce fuel consumption) and that's much more profitable. It would also be a huge benefit in terms of pollution. Definitely desirable. Definitely financially viable even if each ship engine costs tens of millions. Maybe feasible. Far more feasible than using fusion engines in cars, that's for sure.
But not cost effective right now, you may as well just use oil.
There are very limited commercial reactors on ships, the vast majority will be on military submarines, though I think Russia has some on some ice breakers? Not sure the reason why you would do that, it would be very expensive.
SMR's may be the future instead of the larger conventional fission stations, though I doubt they would work too well on ships - SMRs are designed for steady continuous power output.
In addition, physics doesn't change over time, we will still need the same amount of shielding today as we will in 1000 years to stop Co-60, so you would be adding bulk and mass to your ship.
Fusion is also not clean. The neutrons produced in a fusion reaction activate elements in the materials of the machine to create radioactive isotopes. E.g. Cobalt-59 in stainless steel is activated to Cobalt-60 which is a gamma emitter with a half-life of around 6 years. Although we won't create High-Level Radioactive waste, we will produce vast quantities of Medium and Low-Level Waste which must be handled as radwaste and which still needs to be packaged and stored for several years.
One problem with articles such as these is that when scientists say XXX will be possible in YYY years time, the scientists often have not given much consideration to the future engineering challenges to be faced in actually realising the theory. A big problem with fusion is the time frames people have put on what is an incredibly complex challenge. It has always raised unrealistic expectations.
It is certainly interesting to see modern computing approaches helping, but in reality, if AI could solve it all then we have just wiped out millions of jobs across the world.... AI cannot solve all engineering design challenges. Engineering is a combination of creativity and logic. AI, I suppose, is cold, hard logic. There are thousands of engineers at ITER dedicated to design and analysis to support the science with perhaps tens of thousands of highly-specialist technicians and operators in the supply chain. AI would also not solve supply chain issues.
The major issues related to realising fusion, at least in Tokamaks are:
All of this is on top of the fact that a fusion reactor is a nuclear installation and must therefore be licensed by the state agency responsible for nuclear safety. This itself is a huge challenge, particularly for a novel plant like a fusion reactor. "Beginning commercialisation" in 2023 I guess means only just starting the design approval for the reactor, which will take years.
- maintaining a stable plasma - physics
- solving novel material science and engineering challenges to ensure that the machine doesn't just disintegrate and clog itself up with dust created from particles stripped-away from plasma-facing components by the neutron flux
- solving the very complex challenges of remotely-operated handling and maintenance operations inside the vacuum vessel, which are necessary just to keep such a machine running
- the huge material and engineering costs
- breeding sufficient amounts of the required tritium to feed the machine
- treating the radwaste
Very few of the above challenges could be solved by AI.
I am confident that we will see a commercial fusion reactor connected to the grid in our lifetime, but it won't be ITER and it won't even be the follow-up, DEMO.
ITER itself will not generate any electricity, it won't even have a turbine island, it is an experimental reactor. Instead, the purpose is to generate a plasma with fusion power ten times the external heating power applied to the plasma. ITER is essentially a proving ground for the plasma physics, materials science, and engineering solutions applied to the magnetic confinement approach to fusion in a Tokamak machine. At sometime during the life of ITER the member states will begin to construct their own demonstration (DEMO) reactor designs, which will be followed up by commercial reactors.
In any case, nobody I know at ITER would be upset if another organisation suddenly cracked fusion and got it to work. Everybody is working toward the same goal and solving the challenge can only be a good thing for humanity. Although personally, I believe it's probably better for everybody if it was cracked by an international collaboration than an investor-funded private entity...
Elusive, not illusive.
Is the title 'Elusive fusion reactors ' or is this a new fusion technology?
Is Deuterium-Deuterium fusion theoretically viable for a power station? Even harder to make practical than Deuterium-Tritium fusion is, but theoretically possible to do so? That was the impression I got from inexpert reading about fusion.
No, it's Elusive. I pointed this out but my post was deleted
Illusive basically means made up. Fiction.
Anyway, I think today is an amazing time to be alive. We've got the LHC on the go, we've got people sorting out qbits for quantum computing, people are sussing out fusion reactors, Musk is prepping to colonise mars, it's genuinely amazing.
One thing I think the world falls short of is publicity. Back in the 90s there were science related promotional items everywhere. Remember when Andy Green broke the world speed record in the Thrust SSC? You couldn't move without bumping in to it somewhere. Beyond 2000 was a TV show which was all about new and future tech, I loved that show. Do we have anything like that now?
Today's kids seems more interested in what shape Kylie Jenner's eyebrows are today than making actual progress as a species. It's a shame, hopefully the silent nerds are still at it.
As someone who works at ITER, what's your thoughts on the Stellarator's benefits in terms of no transformer need for the alternating magnetic field as well as atom drift vs the Tokamak?I am somewhat dubious of the claims made in the article. The video is very good though, although at the very start he repeats a few common tropes about seawater being the fuel for fusion and that fusion is "clean". I work at ITER, so have a vague idea of the state of things...
Direct with ITER, the jobs at the moment are few and far between, and if you only have a UK passport you are **** out of luck for the moment I'm afraid. BREXIT made sure of that. Maybe if we find a way back into EURATOM it will open up again for sole UK nationals.
There are always plenty of jobs with companies contracting to ITER or F4E though. Provence certainly isn't a bad place to live!
I met a nuclear physicist last year who had some small involvement in fusion research. He didn't expect it to be ready this century.
The other issue is if cheap grid scale energy storage can be achieved first then there no need for Fusion at all and renewables will provide 100% of our energy needs at lower costs and higher reliability
If it really is as beneficial as made out in the video below, why would ITER not switch to it before it's too late?
I like Subject Zero's videos, but as much as I believe he is putting in the research I don't think he's getting the whole story from both sides.
