- 19 Jun 2012
I gave up after 2 hours of "unable to connect to server".
Played Prey instead!
Well, 2nd day of trying to play this bloody game only to sit in the lobby endlessly.
Someone mentioned in a match tonight that you could disable cross platform play if you're on Xbox, so I did.
But then you can't enter any Warzone matches?
Yeah same connection issues here, another issue I have is that occasionally, the graphic options change to "borderless", whereas I use "fullscreen". However when it does this it also changes my screen size down from 2560x1440 by way of the box underneath which changes to "50". Puttting it back onto 100 sorts the issue but it also reduces a few settings, whereas normally it runs the game fine night in night out on max settings. Just a bit of a ballache correcting it.
AFAIK Groundwar and Warzone are crossplay only?
Also having this problem. Tried raising voice volume and mic threshold... Worked but not consistentlyAny fix for the audio, in game chat just cuts out and once back to lobby works fine again.. Really difficult to play without communication
Some people are such saw losers
I was just playing a game of Search and Destroy with my new upgraded Uzi. No stock, Carbine pro barrel with .41 AE 32 rounds. Dead Silence and double time enabled I wiped out there whole team in about 5 seconds... 4 of them left.
