Hi all,
My current PC was made back in 2010 with the following specs -
i7 2600K @ 4.6ghz
OcUK CPU Water-cooling with 120mm Rad
Asus P8P67 Pro Rev3.1 MoBo
16GB XMS3 DDR3 @ 1600
Nvidia GTX 580
In the ten years since buying I swapped GPU's from a 580 to a 780 to a 1070 and replaced the original "water-cooled CPU setup" with an Alpenfon Matterhorn Air Cooler (for less maintenance rather than for any extra performance), but thats all in 10 years and, with the constant GPU updates, it is still able to play all my games at 1080p at 60fps right now without issue and usually at the highest detail/quality levels.
However, while everything still works fine right now, I know that at some point my poor CPU/MoBo or RAM will eventually fail and I'll need to swap to a whole new setup but, having not had to worry about upgrades for such a long time I'm slightly "out of the loop" although a few Youtubers reviews are helping me catch up.
With that in mind I'm wondering what currently available CPU would be able to give me the same "still playable after 10 years with just GPU upgrades" i got from my 2600K for the best VFM (Value For Money) whilst doing so (no threadripper please
Thanks!
My own opinion is that I can't believe 4C/8T will still be adequate 10 years from now, I think 6C/12T would be the absolute bare minimum and it's more likely that 8C/16T and higher would be required to buy right now to still be considered adequate (with say 2 newer GPU's like I did) in a decades time.
Of course when I got the 2600K we had a 6+ year period where Intel's dominance effectively hamstrung home/game CPU development into "4C/8T only" for far longer than it should have been (with a static effect on "multi-core" games development too) plus we were generally "stuck" at 1080p for a long time. So now AMD's resurgence has seen home CPU core counts skyrocket and 4K and 144hz gaming taking off I can see the next decade being where games/software really starts to heavily leverage this new "core race" and it makes me wonder if even 8C/16T will be enough in a further 10 years time for whatever the future of PC's looks like?
i7 2600K @ 4.6ghz
Nvidia GTX 580
Thanks!
