The higher the CAT doesn’t mean it’s a better cable, it’s a different specification, there are trade offs.
For instance CAT5e is very flexible and can be put round much tighter bends than a CAT6a cable before it breaks. CAT6a is very stiff in comparison. CAT5e is also far easier and cheaper to terminate and just deal with in general if you need to make your own cables.
