New PC needed - out of the loop!
23 Apr 2006
Nottingham
Hi there,
Been out the PC/gaming for a few years and now need to build a new PC. I could currently get a full system around the following for 600:
CPU - Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151
Motherboard - Asus Maximus VIII Ranger Intel Z170 (Socket 1151) DDR4
Memory - Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel
Graphics Card - Zotac GeForce GTX 1070 AMP Edition 8192MB GDDR5
It will only for stuff like Anno 1800 and Cities Skylines (fully modded) for now and was wondering, for the price, should I look at something else as I see a lot of systems around AMD now (shows how long I've been out the loop haha).
Thanks!
18 Oct 2002
B450 TOMAHAWK MAX mother board.
Ryzen 5 3600 CPU, this alone will save you money and give you a good gaming machine base. In fact for nearly the same price of the Intel Core i7-6700K 4.0GHz you could get a Ryzen 7 3700x which would utterly destroy the Intel choice..
Asus Maximus VIII Ranger Intel Z170 (Socket 1151) DDR4 = this is an end of life item.
19 May 2019
London
Yeah that fully system intel build is not the best value for money right now. The main problem is that you are hitting a dead end platform with no real path to upgrade. At least with a AMD AM4 socket, you can get a 4 core CPUs with the potential upgrade to a 16 core CPU. There are much better choices around right now, in terms of value and future upgrades
OP
23 Apr 2006
Nottingham
Thanks everyone. The last PC I had myself was the i5 2500k, back when Intel had the market (over 5yrs ago when I sold it). So, I can see that a lot has changed. The full system build does include the whole base unit and thought it was good value for the price (considering the 1070 too), but I guess I was waaay wrong! haha.
I don't have much more in the budget, perhaps stretch to £700 at push.. Is there anything I can get around that or am I better saving for parts on MM and if so, what parts to look out for?
Am I right in thinking that something like Cities Skylines loves a good CPU too?
19 May 2019
London
If you can build it yourself, you can easily get a balanced ryzen 5 2600 with something like a GTX 1660 Super/ RX 5600XT for less than £700. Pre built from proper custom builders, probably more on the £800
OP
23 Apr 2006
Nottingham
Yea, im sure I can still build a PC (he says haha).
In terms of components like CPU/Mobo, what should I be looking out for these days?
I saw that the 1660 S seems to be perform similar to the 1070, so if its cheaper, its a no brainer.
Thanks!
Caporegime
17 Jul 2010
Thanks!
No point in moving from your 1070 to the 1660 Super imo. It's a sideways move at best.
OP
23 Apr 2006
Nottingham
Apologies, I probably confused the matter. I dont actually have any PC at the moment (sold my last one over 5 years ago). I've just seen one around £600 with an I7 6700k and 1070 etc and was wondering if it would be a good buy, especially with changes around AMD and the fact I havent looked at getting a PC for quite a few years haha.
30 Jul 2007
Lincolnshire
If building your own, here's a base to work with. Obviously you can spend a little more here and there, dependent on budget...
e.g. could pay £37 more for 1TB SSD, £30-40 more for a 'better brand' PSU (personally don't think these Kolinks are bad) etc... You get the drift
My basket at Overclockers UK:
Total: £792.89 (includes shipping: £0.00)​
11 Jan 2009
That is a pretty cheeky little build that :)
