AMD RYZEN 3 3100 & 3300X NOW AVAILABLE TO PRE-ORDER FROM OcUK
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
AMD can now give you around i7-7700K performance with their entry level Ryzen 3 CPU which comes at a bargain price that still packs a punch. Of course for those who are looking for a lot more power you can get the Ryzen 9 3950X with a whopping 16 cores / 32 threads.
Check out these two new amazing CPU's:
AMD Ryzen 3 3300X Quad Core 4.3GHz (Socket AM4) Processor - Retail @ £113.99 inc VAT https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3c0-am.html
100-100000159BOX, 4 Core with 8 Threads, 4.30GHz clock speed, 7nm FinFet Process, 18MB L3 Cache, Dual Channel DDR4 Controller, 3200-3600MHz RAM Recommended, 3 Year Warranty
Only £113.99 inc VAT.
ORDER NOW
AMD Ryzen 3 3100 Quad Core 3.9GHz (Socket AM4) Processor - Retail @ £94.99 inc VAT https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3c1-am.html
100-100000284BOX, 4 Core with 8 Threads, 3.90GHz clock speed, 7nm FinFet Process, 18MB L3 Cache, Dual Channel DDR4 Controller, 3200-3600MHz RAM Recommended, 3 Year Warranty
Only £94.99 inc VAT.
ORDER NOW
Stock due next week! :)
We are expecting big sales on these as they are incredible value for money!
Yo man! If on a budget then Quad core now with a nice B550 mobo means you will more than likely get a stellar upgrade path to Zen3 and at least 16c/32t or beyond, damn kickass if you ask me!!! Especially if paired with some nice DDR3 from the outset :cool:
good luck with plugging in DDR3 ,,, crowbar? :p
but how does it compare with a second hand 1700 or 2600 for £75 ?
Multi threaded I would assume that the 1700 or 2600 are going to be faster. But in single threaded or lightly threaded workloads I would expect even the 3100 to be quicker.
This has gave me an upgrade itch...would be a cheap upgrade from my i5 2500k.
Not sure to go for something with more Cores and Threads though...I don't upgrade often.
I'm still rocking the i5 2500k like you.
I'm tempted to upgrade currently but think I will wait for new AMD processors later this year and bag a bargain 3700x or 3900x. Gotta be worth getting more cores now, based on how reluctant we are to upgrade it seems. I want 8 core minimum to see me through the next 5+ years.
If you even wait a month until B550 boards come out then start with the 3300x...then plenty of upgrade paths over next few years 6>8>12>16 cores
Will B550 support anything after zen 4000? AMD said AM4 supported until 2020, so Zen 5000 (?) could be on different socket?
1700 or 2600 will have the advantage in threaded situations e.g. newer games, and for "serious" work, however 3300X will have the advantage in most current games due to increased IPC, better Memory support etc.
1700 is probably a better choice than 2600 if looking for longevity, as it has 8C/16T the same as the forthcoming console updates.
Go for 8Core /16 Thread if looking for longevity e.g. 3700X
Will these just slot straight into my Gigabyte AB350 Gaming 3 board (currently with an AMD5 1600?) and f50 BIOs?
If it already has support for 3xxx series chips (e.g. 3600/3700x) then should just drop straight in.
Depending on your budget. Go for this with a decent B550 motherboard then you can drop upgrade (s) for years to come. PCIE 4.0 and Zen 3 will last you a long time.
It will be on a different socket, plug in a cheaper CPU now and later add cheap upgrades. A decent B550 should take a 4000 series 16C.
