Man of Honour
- 8 Nov 2007
- Outer Space
No sign of the update for my Gigabyte board
i found a problem with the MSI B450m Mortar Max
when i change the Termination Block in advanced DRAM setings
i manualy tune the (procODT, RTT_NOM, RTT_WR and RTT_Park) save and boot to windows
I run ryzen timing checker i see no change
ProcODT case show no value (blanc)
Rtt_nom, rtt_wr, rtt_park are disabled!
When i go back to bios the changes are persistantAs long as it's set in the BIOS, I would believe that over Ryzen Master. Perhaps Ryzen Master needs an update or a reinstall to see the changes reflected in the bios.
7B78v1E3(Beta version)
Description
- Updated AMD AGESA ComboAm4PI 1.0.0.6
There is a new BIOS for my MSI X470 Carbon on the support page..
https://www.msi.com/Motherboard/support/X470-GAMING-PRO-CARBON-AC
Not sure if i should update to this.
Anybody on 1.0.0.6?
This appears to be only for x470 and b450 boards and from what I've read about it, introduces per ccx overclocking on Ryzen 3000 CPUs for those boards, it's up to you if you flash it or not, I'm running an MSI beta bios now, never had a problem with them, MSI seem to be quite quick to release them.
Thanks for the info, might do an update later then. I just hate having to manually put my settings back in as every time i use the BIOS save option to a USB it never bloody works on a newer BIOS lol
With a new bios, youi should set it up manually anyway rather than use saved settings, things change and get moved around, I would never load old settings in a new bios.
Still nothing for the x570 tachi not sure whats taking them so long.
Anybody on 1.0.0.6?
I personally would only update to a beta if my current bios was giving stability issues. Just wait a week or so for the non beta and let someone else find the bugs.
Bios 2010 is now official for the Asus Hero Crosshair VIII.
https://www.asus.com/uk/Motherboards/ROG-Crosshair-VIII-Hero/HelpDesk_Download/
Boot time seems to have improved, think it was around 20secs and now I’m on 9.9secs, otherwise everything else feels okay.
