Um, the chart above shows the 7700K at stock getting beaten and the 7700K clocked to 5.1GHz matchedIt still lost to the 7700k in all the tests though so a scaled up 8 core version would still be behind the 9900k.
How many people run the 7700k at stock though or the 9900k.Um, the chart above shows the 7700K at stock getting beaten and the 7700K clocked to 5.1GHz matched
Some quotes from Gamersnexus:
"AMD gotten what it deserved and it's fans got a bit of wake-up call".
"AMD has a history of obtuse marketing which plays to the cheap seats".
"AMD is now a big boy company and it's fans need to realise it's one".
"AMD knew lack of compatibility would cause issues".
"AMD wanted to announce the 500 chipset news around Zen3 support and the lack of 450 and 470 Zen3 support before the Zen3 CPU launch because AMD wanted to pre-empt that launch and AMD did not want all of this to overshadow a new CPU launch and wanted to give a chance for people to sit and simmer or sit and stew depending on the news".
"After talking to people familar with the matter, AMD didn't expect the backlash to be this bad".
"AMD should have spent all this time building up it's own products instead of making a self righteous post about how Intel is repugnant for not supporting its CPUs past a single socket".
Not sure AMD will want to send him any review parts after that!
It also shows AMD definitely knew for a longtime that B450 would not work,they knew not making B450/X470 incompatible would cause a problem,and didn't give a damn about what people thought,so decided to keep quiet until it suited them,ie, to not affect the Zen3 launch.
So,in the end no better than Intel NOW really.
The 'solution' AMD came out with to 'solve' the bios compatibility issue (sending out compatible CPUs) AMD created was just another level of hassle even though it addressed the problem and of course it was probably unsustainable from a cost per
Irrelevant.How many people run the 7700k at stock though or the 9900k.
Sp you're suggesting that AMD should've switched up their CPUs every generation so they're physically incompatible with previous generation boards? Funny how everybody is decrying AMD for "doing an Intel", yet you're saying AMD should've "done an Intel" from the very beginning.AMD's biggest mistake here was making a family of CPUs (they all have the same name, socket, pincount, RAM compatibility) so mutually exclusive they do not even post on a board without a specific AGESA. Amateur hour execution.
Atleast if they had of changed sockets then people would have been clear what they were buying into. AMD kept quiet so they could sell a bunch of B450 boards then make the same people buy a B550 if they want next gen.Sp you're suggesting that AMD should've switched up their CPUs every generation so they're physically incompatible with previous generation boards? Funny how everybody is decrying AMD for "doing an Intel", yet you're saying AMD should've "done an Intel" from the very beginning.
But then when Intel have done multi-generation support you still needed a BIOS update. 60 series boards wouldn't boot Ivy Bridge without a BIOS update, 80 series boards wouldn't always boot Devil's Canyon, same with 100 series boards and Kaby Lake. Pretty sure Rocket Lake isn't just going to drop into 400 series boards and run without intervention.
Lol, this thread is getting hilarious.Atleast if they had of changed sockets then people would have been clear what they were buying into. AMD kept quiet so they could sell a bunch of B450 boards then make the same people buy a B550 if they want next gen.
AMD marketing is amateur. like it or not atleast with Intel you know where you stand.Lol, this thread is getting hilarious.
"AMD has done an Intel! Pitchforks!!!"
has suddenly become
"AMD amateur hour! If they'd changed sockets every time like Intel then they'd never be accused of doing an Intel!"
They will still need to do that with X570 and B550 if the board has not been pre updated.
A 32mb bios chip and or bios flashback is the minimum I expect before I buy into AM5 after this debacle.
Also I think AM5 will now come under more scrutiny with people wanting to know where they stand on future upgrades before buying into the platform and AMD will have to be more clear now as the trust is gone.
So what is everyone doing? Waiting for i5-10600KF or sticking with Ryzen 5's and 7's
They lost the sale of the 4900x I had planned to drop in at xmas so now that £500 will probably go to nvidia as I will likely get the 3080ti as opposed to the 3070 or 3080.I won't be buying future 3000G 'support' CPUs or 1600AF 'just to have a play' CPU, or suggest people buy a mid-upper range CPU now and then upgrade to the top CPU 6-9 months later of the platform compatibility isn't there. It will be buy a platform once and then sweat it. I'll probably not even be on the bleeding edge as a willing alpha/beta tester so AMD will lose margin too. I'll be able to buy a better turbo more often then.
And also the ryzen is being run with 4x 8gb of 3200/14 ram which most people buying a £120 CPU will not spend £250 on ram.
one of the truest statements i seen on here. said this many times. AMD you have no idea what your getting or where your going. Intel atleast put it out you know where you stand. this is a big thing as well and why many just choose intel like nvidia for their products.
its absolutely comical to see the new amd chips wont be supported on previous boards yet many here sang and cried about evil intel developing dead end sockets.
on the new AMD cpus i think these will be what most actually wanted from what we have now and being absolutely brilliant cant wait to see what they can do. bring em on.
Are Intel fanboys seriously arguing over 1%? Intel has a 30 year history of needing high frequencies to make up for their low IPC.
