Thinking of a Sabrent Rocket to use as a boot drive to speed up my windows a wee bit - what's the best size just for windows ?
Zero reason to go for multiple small drives.
Especially on M.2 drives with very limited number of ports for them, it's best to buy the biggest size you can afford easily.
For easier organizing of data on same drive there's good old partitioning.
And it doesn't matter on SSDs, if there are half dozen programs doing random accesses around drive simultaneously.
In fact having dozen+ programs doing that is the only way to reach those advertised IOPS numbers:
Random access read performance with single access at time from single working thread is only little better in NVMes than in SATA SSDs.
And big marketing numbers are only achieved by having many reads going on in parallel and with big pile of them in queue for controller to be able to choose from for optimal pattern of accessing actual NAND cell locations.
(kinda like NCQ in HDDs)
Actually small drives of model serie usually have lower performance numbers, because of lower drive's internal parallelism.So best performance comes from just one large drive on its own?
As said above, yeah you want 1TB to get full speed especially if PCIE4.0 speeds and think about upgrading, which is why I went overkill now on the NMVe when I can't even get 4.0 speeds, but I know that i'll get better performance when I do switch in a year or two rather than buying a lower spec one now then not being happy! Go big or go home lolSo best performance comes from just one large drive on its own?
Question save making a new thread.
I've read the above I'm picking up a Sabrent Rocket for Steam and general storage.
Was thinking of picking up a 250 gb NVME drive just for the OS to use as a boot drive is this not advisable anymore then?
Thanks
