The weight will be spread over all 3 legs no matter where you sit....
It's not about the total weight, it's about stability. If you use a 7ft bar then your loads are a substantial distance from the centre point.
Do you not put your legs on the floor?![]()
Have I stumbled into the twighlight zone? Bench looks fine.
The weight can be any distance from the point of contact?It's not about the total weight, it's about stability. If you use a 7ft bar then your loads are a substantial distance from the centre point.
I think @Dis86 is in an abusive relationship with his current bench, he just wants some stability and comfort.
I'm at about £2100.
Bench
Rack
Dumbbells - 8, 12, 16, 20, 26, 34, 42.5
Bumpers - 20x2, 15x4, 10x2, 5x2
Hex Plates - 2.5x2, 5x2
Bars - Ez Bar + Tricep Bar
Floor mat
Land mine + T bar.
The bar is on loan from a friend until I can source one for a reasonable price, which will be another £180.
It's a very good bench, not sure why you think it would be unstable? Doesn't move at all. Had another like this before, exactly the same and it comfortable handles me bench pressing 150kg+
It's identical to pretty much all the commercial gym benches used.
https://www.powerhouse-fitness.co.uk/taurus-commercial-weight-bench-b950.php
it doesn't look too stable tbh
https://www.fitness-superstore.co.uk/body-solid-flat-incline-decline-bench-2.html
that is my bench or a similar model to mine as you can see it looks far more stable
clean set up. i'll be getting the same dumbells when they come back in stock.
what bench is that i have a body-solid at the moment but i should have sold that and kept the gym ratz one i had but i can still sell and get another.
i just sold my full dumbell collection for over £3K paid about £500 for it second hand way back in the day.
I thought as much. I'll need to see what I get for my bench. Hopefully £300 plus then I might get the same. I want something more compact mine takes up a lot of space.
Also @Psycho Sonny I thought you were buying the same bench as me because you liked it a few page back?
