- 13 May 2020
Hello I'm hoping firstly that I'm posting this in the right area and secondly there is someone that can perhaps help.
After many years of the promise of full FTTP on Monday Gigaclear final connected us up from the pot to our house.
hopeful this would be the end of shouts from upstairs of my son telling me he is laggin.
The install team though polite turned up with the incorrect tools as apparently they didn't know it was going across a drive.
after approximately 2hrs they where done and told me to log on to the Linksys velop add passwords and i would have to set the rest.
Being told this was easy and then it would be all complete.
I done a speed test on the Gigaclear speed checker via Wifi and Samsung Phone and came Back 216Mbps Download and 340 Upload the Gigaclear Guy said this will improve within an hour or so.
he went on to tell me I would receive Wifi speeds if in the right area of near on 900Mbps.
I was also told that the 3 spare ports on the Modem (Small white wall mounted box) could be used as i wanted to run my PCs and Games consoles Via Ethernet.
After hours of faffing about with unplugging testing and retesting found that the speed never increased the ports on the modem do not work and that my wired max speed is 200Mbps download and 400 up.
phoned Gigaclear support and emailed and have been told to reset and unplug all connected devises and reset everything.
Done this and the wired speed is still only 200Mbps Wifi close range is about 180-200Mbps
the Wifi range and speed id perfect and i never thought that any of my devices would be able to run wifi speeds higher than 500Mbps
but the wired side i though paying for 900Mbps i should be getting that speed.
Not sure what the problem is but from the Gigaclear powered by Linksys modem ethernet to the Linksys Velop ethernet out of the velop to my Pc
Any help or advise would be much appreciated
as so far the only really quick thing about Gigaclear is the bill which arrived the next day
Thanks
Thanks
