Permabanned
- 13 Sep 2011
- Usa
So for a ryzen 5 3600 and a gtx 1660 super what would be the lowest power supply unit that would be safe?
A decent 550w unit would be fine... Seasonic and Superflower would be on my list some of their units come with nice lengthy warranty
No corsair txm gold?
No overclocking I don't think its needed really. Maybe ram?? But I am planning on sticking with a Ryzen 5 3600 and GTX 1660 Super for the next 3 years at least. It's going to give me the performance needed to be able to play latest games for a while yet?
RDRII is probably the most demanding on hardware right now, you should be able to play that at 1080p 40ish FPS? So less demanding games 1080p no problem.
Thanks for that I will stick with 550 then I guess. What about an rtx 2060?You could run an R5 3600 and 1660 Super on a 450W, but you don't usually save much over a 550W.
Most systems can run fine on 550W. An RTX 2060 Super doesn't use a lot of power either, so a 550W would cover that as well.
Great thanks for that! Any suggestions on a cooler with good ram clearance for a ryzen 5 3600?
These have any issues with ram clearance?I like the Arctic Freezer 34 esports/esports duo. Out of stock on here at the minute, but they should be available elsewhere. They do a few different colours.
https://www.arctic.ac/uk_en/freezer-34-esports-duo.html
My basket at Overclockers UK:
No they should be 100% fine with any Ram.
Looked at some video reviews and it was pretty cool. I think I shall be using this as I was planning on putting an exhaust on the top of my case along side the back exhaust. The case will have two big fans on the front for intake as its mesh front for full air flow. And it can have a fan on the very bottom also. What arrangement would you suggest?
