How come my 3600 hits 1900 IF then and many 3900x dont?AMD dont only bin cores, they also bin memory controllers or IO dies if you prefer, which is why you find 3800X's better than 3700X, better binned parts.
Its still essentially the same parts just better binning.
It's not binning, it's a new process, N7P.
Isn't that why they bin though to take the luck out the equation.You got lucky I guess, happened with me back with my 1700, its all I could get at the time, the 1700X and 1800X sold out so quickly, overclocked it to 4ghz, the same as the 1800X for £200 less.
This is probably why we are just seeing these high clocking parts now as there wasnt enough faultless silicon available last july so we got the dumbed down versions instead of what AMD had originally intended and the pre release leeks shown. Now they can just slot these into the exsisting line up as they probably have a stockpile now and rather than just let them go into existing sku's they can generate some publicity and extra revenue for being able to charge a slight premium.And that my friend is binning, the 8 core chiplets that perform faultless and extremely well go into the 3950X and Epyc
That is the logical answer as opposed to being N7P. They could be but I’ve not heard it being confirmed beyond forum speculation.This is probably why we are just seeing these high clocking parts now as there wasnt enough faultless silicon available last july so we got the dumbed down versions instead of what AMD had originally intended and the pre release leeks shown. Now they can just slot these into the exsisting line up as they probably have a stockpile now and rather than just let them go into existing sku's they can generate some publicity and extra revenue for being able to charge a slight premium.
They will still continue to go into the 3100 3500x 3600 4700x 3900 etc and these will still be selling plenty just like with the 2600 being one of the most popular chips even after zen 2 released. the 3600x and 3800x are the only skus that will likely be phased out and replaced as there wasn't really much value in those anyway at their current specs.Its possible, but like I said before, what are they doing with all of the ones that still are not making the grade, you'll always get bad ones, they're not putting them into the lower end chips like the 3100 and 3300, although they have a lot less cores, everyone is talking about how well they are overclocking, and thats usually what they would do with the rubbish cores.
Pannalicour game engines are no more designed for Intel than designed for SSD. Have you seen the load times on spinning disk?
Unoptimized code will prefer low latency, end of story.
Ok, i'll re-quote Minstadave
So which is it? Same process, better binning or new process, not binning?
If it's a new process with the same underlying architecture and configuration of Zen2 then it very much smells like a Zen2+ even though AMD haven't shown marketing as such this time around.
Thats my fault, N7P isn't official so may not be true.
It's not binning, it's a different configuration? See 3300X.
Don’t think I’ve ever had a decent chip that overclocked well. My 4670k was an absolute turd.
By laws of average my next chip should surely be golden.
overclocking isnt what they make these chips for, they are made to meet their specs, nothing more.There shouldn't be a lottery between a 3600 doing an FCLK of 1900 and a 3900x that can only do 1800.
They should bin the IMC's off. Also this would help segment the line-up and actually give a reason for someone to buy a 3800x over a 3700x.
