Fractal Design, new case/s 03/06/2020
18 May 2010
Hello,
Looks like fractal are unveiling some new cases next week, anyone know what they are?
They look like define's in the Instagram post but it's hard to tell, I'm hoping for an updated Nano with Tempered Glass and PSU shroud, instabuy if it comes in white.
I dunno on the Instagram pic it looked like it had a flat front but could be wrong. I currently have a meshify C and I'd be interested in a white mini revised version
Typical, just replaced mine with a Meshify C!
I imagine it will be slightly longer though, think the Meshify C could do with another few cm graphics clearance. I imagine they'll want to address that in whatever replaces it.
Been using mine for over a year and it's been awesome so don't worry it's a great case, I just get bored and fancy a change plus I love fractal cases
Agreed, it replaced an NZXT S340. and whilst that was a greaty case the Meshify C is jsut a pleasure to build in.
I managed to find the model number, already listed on Amazon too, put FD-C-DEF7C-01 into google and it throws up a bunch of results about the Define 7 Compact
Confimed Define 7 Compact
Yup just seen it pop up on Instagram, need to have a look at the dimensions and see if its any smaller than my Meshify C and then if it comes in white I'll be tempted but will probably hold out for a Nano. I think I'll be waiting forever because I think they are going to do another Node soon
I had a quick look, and it is a couple of mm's smaller than the Meshify C , also unfortunately it only comes in black , asked on twitter no white.
The wait goes on..
Hardware Canucks put a review up earlier, definitely not for me
Like Jeff B says, the wait for the perfect upgrade continues, a white Nano would be an instant purchase for me but there is no indication it will ever exist and Lian Li TU150 grows ever more tempting
I bought the compact from OcUK on Friday and built it yesterday. Really quite pleased with it, I was upgrading from an old define r5. The only annoying thing is the cable management from the PSU as mentioned by Hardware Canucks. If you don’t get it right the side panel will pop off. I just removed the 3.5 drive cage from the bottom and that made cable routing much easier.
