I did the same as soon as i installed Win10. Sounded similar to the old ‘RAM booster’ programsWas getting loads of inconsistent frame rate issues in this and stuttering. Did some digging and turned off game mode in windows, loads better. Read of a few issues with various games including this with it on.
Pretty much this. Shoothouse is probably my favourite map in CoDMW currently.
A lot of people seem to be using it in Warzone. I tried it for a bit and it was good but just didnt feel right for some reason...but yes, it’ll probably get nerfed soonDo you think they’ll nerf the Grau? It’s deadly with stopping power.
Took them too long to add it in!Warzone Duos is flipping rad![]()
So made sense to add Duo’s then.Think it will make trios tough now as it will ONLY be full parties of 3. In the past there were loads of 2 person teams in trios I found.
A few of my friends play Warzone but do not have the full multiplayer game. How do Warzone only players build their loadouts, can they?
I want them to run cold blooded and ghost if I am. There’s not much point me using these perks if others in the squad don’t.
They stand out like a sore thumb to thermals, scanners and uavs which in turns means i’m usually with the squad so will be found too
Thanks. I wasnt sure if they got the weapons tab option because I only access it through multiplayer.There's no difference. They can build their loadouts just the same as you can under the weapons tab.
Mines also on moderate and I have no issues finding any games.I have moderate NAT type on PC. Is this good or do I need open NAT? If this is better, what is the safest way to get an open NAT type?
I dont think they have yet. I was on BR solo tonight. I unloaded 30/60 clip on someone with stopping power round on my MP7. He then took out his Grau and i was dead in about 3 bullets! I might go back to using my boring GrauI think they have stealth nerfed it. its been weak recently with pinpoint aim. others have noticed it too on Reddit.
