My Powercooler runs 40C idle on chip and 45C on TJ so that seems a little high at idle. However, I took the thermal paste off and also put some decent Artic Silver 5 on as the stuff they put on standard is crap and didn't even cover the die properly.Hi All , My red devil has high idle temps of 50c - 52c is this normal?
I'm running 3 screens and not had those problems, you running over display port? The only problems I've had is now and then then settings within Radeon reset due to a problem, and I hear something disconnect and connect so imagining that's my monitors, but all is ok, nothing goes off screen. I've been running the last two versions of the adrenalines...Having problems with black screen crashes with my 5700xt! What’s the process of trying to remedy this? Is it just a driver issue? I’ve seen there are quite a few problems with those
I’m running two screens as I’m streaming and need to see the chat etc in another window
Have you got pcie gen set to 3 instead of auto? Any motherboard or uefi updates?
Prior to installing 20.5.1, and the apparent long spell of no issues, the MB was running on pcie auto and no recent chipset driver update or bios update had been applied (Crosshair Hero VI). The bios is the latest anyway (7704). Following 20.5.1 and the sudden wave of black screen crashes, I did set the pcie to gen 3 and update the chipset drivers. That made no difference, the crashes continued.
No mate sorry not used it at all sorry. I use Bandicam for recording aything I need to, however it was my next task to see how this streaming works.@pugheaven I hope you don't mind me asking as I'm curious, but have you used OBS and/or the Radeon software to record any gameplay footage, and if so, how reliable/good an experience has it been? Cheers.
I'd go with that as I had to remove a patch as it knackered a few things up... the last couple of windows patches around 1909 have been poor imho.Any recent windows update that might be affecting your rig? Have you got a spare drive you can slap a fresh copy of windows on or even Linux to rule this out?
Yeah same here. It depends what you mean by idle. If I close all YouTube tabs then I can run with fans 0 rpm, but once I ask the GPU to do anything the temps creep up until the fan auto kicks in and then its an annoying fan on/off cycle, so I leave fans always on lowest rpm when idle. My next AIB cooler will be a 3 fan design and longer card/cooler. Also its probably my low rpm case fans for silence that aren't helping. oh and the fact that there is 3mm clearance between my GPU and ATX PSUHi All , My red devil has high idle temps of 50c - 52c is this normal?
I have a plan for that too!The last listed update for Windows on my system was 26th May. This run of black screen crashing started on June 5th. So 10 clear days with no issue until the problem hit, hmm. Given the random nature, it's hard to determine anything by removing that update I would think. I will look at setting up a portable copy of Windows on an external drive or stick and perhaps investigate running from that. Day two on the old R9 290X though is proving to be problem free and well, slower..Any recent windows update that might be affecting your rig? Have you got a spare drive you can slap a fresh copy of windows on or even Linux to rule this out?
