Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
To go with my single dose workflow, got this to keep the beans fresh.
It’s great. It looks and feels great. Really quiet to use and really easy to change the grind settings. I like the little pot to tip in portafiller. It’s not completely zero residual as sometimes there is a little bit falls through later or with a brush out which I notice as I tend to leave the pot on my scale, but It’s so small that I really don’t think it matters. It’s just fantastic for single dosing really.
When I see them with some scale I'm always a bit surprised how big they are, the shape makes them look tiny. Would like to try one out someday.
I'm tempted to have a little DIY project to make a grinder. My mate has a full workshop...I figure buying a pair of big flat burrs and a motor and some kind of mechanism, how hard can it be? :}
well, with the fine adjustment needed, the cost probably comes from the mass production of precise machining.Based on the price people charge for the machined ones it must be very very hard to do properly, but really how hard could it be...
I am no engineer but I guess you will need to
1 - source a good motor with the right torque and gearing
2 - Figure out how to do the entry, grind and exit route with the least amount of retention
3 - mount it all in an enclosure so that it doesn’t fly out in all direction. So you need to design a chamber.
4 - mount everything securely so that it doesn’t vibrate itself off the table
5 - Design it so there is access to adjustments of grind
6 - Design it so you can take it apart with hand tools
7 - Safety in terms of what happens if it slips and blows up inside? Torque cut off? Overheating safety cut off?
I have a Sage Duo Temp partnered with a Eureka Mignon. When I first got the kit, i bought some measuring glasses and electronic scales to get the right extraction but as time has gone by, I can't be bothered to dial in new beans every time. I am sure my enjoyment of the coffee has declined because of it![]()
You can single dose with the mc2, but its not ideal. I weigh the beans, add to the hopper, grind through everything and re-weigh in the portafilter.
Do want a Niche though!
google says grind retention on a mignon is 0.18g, pretty small, so if you just weigh the beans in, repeatability shouldn't be an issue ?I have been away from Coffee
I have been away from Coffee forums and threads for a couple of years so had not heard of the Niche grinder mentioned here.
Just looked it up and it seems fairly expensive for what seems to be a single dose grinder. Wow
