Caporegime
- 9 Nov 2009
- Planet Earth
Looking at all the phases on the B550 motherboards,it makes me wonder whether Zen3 based CPUs will be a bit of a power hog??
If they are high clocked they might be.
If they are going to be a bit of a power hog, it's a fair assumption that they may well be a heavy heat producer as well.
what did most people moan about or worry when choosing mobos previous and current gen ? whether the board had good VRMS. so they done what they should have done first time round. this is why you dont buy the first gen of anything.
If most people actually took the same view, no one would buy any Intel mobo's because most of the them are not only First Gen but are also Last Gen at the same time.
so you gloss over the main reason i put. then looks at what you own. this forum is so AMD supermarket. lol.
look at what i said take off the AMD hat and see the logic. out of all what i put the first thing you thought of was INTEL ! lol.
what stopped people buying AMD motherboards or would you want to change to get more people to buy them when you release your next product ? you would look at what didnt work or wasnt optimum last release. then change that and keep the good.
bad VRM design or heat issues put many people off. now literally most of the 550 range are really well done. like the 450 and other boards should have been in the first place. often it takes a release so you find all the things you didnt get right or dont know will happen to fix in the next release. thats why you never go off the first run of new things as you are the guinea pig. many amd boards couldnt cope properly with the cpus they were supposed to take and got to over cooking temps.
now thats fixed. which is great. not only that they offer new boards now and took off the other major stopping point of people buying AMD the stupid little fan which wasnt even needed. they havent done that for no reason. they done is so more people will buy with confidence. which is brilliant for many on the fence of swapping to AMD or current AMD people looking to upgrade. you now know you can buy a board with great VRMS which you dont have to worry about also know you dont have to worry about the small fan noise or it breaking and having to change the mobo.
Secondly even after multiple explanations you still refuse to understand why PCI-E 4 requires cooling. X570 uses a PCI-E 4 chipset link to the CPU. X550 uses PCI-E 3 to transfer between the chipset and CPU.
Does this mean that going forward all new boards in the future with gen 4 on the chipset will require a fan or is there a way around this?.
Amusing that dg waffles on about a chip-set fan like it's somehow a big issue. My board has one and I've yet to even hear it. Any noise it might make is less audible than the case fans so what is the issue exactly? Another pathetic point scoring exercise that has zero relevance.
to you. some people on here have had issues with them. also how old is your board? still pretty new. imagine in a few years time if bearing goes. you gunna have to bodge something on the board or...replace it. when a fan isnt even needed. so please dont call it waffle its a genuine concern and put many off buying 570 boards. why even take the risk ? when you dont have to ? people have there pcs for upto 5 years or more. having a tiny fan is asking for trouble. its not about hearing it. it about if it fails. also some people when putting gpus in they have heard noises or certain boards and designs it can cause issues. do you think amd have just made fanless boards right now for NO REASON ? they done it to give customers confidence and not to worry about the fans. i get if you got one but please dont act like its not a concern for many people.
Its only a "genuine concern" for you in point scoring shilltel mode as usual. By the time the fan gives out the board will be long gone. And if it does somehow give out when the warranty expires there's this thing called "the internet" where you can type in the serial number and get a replacement. So toddle along.
i remember when we used to put fans on bare chipsets to overclock them harder. How times have changed lol
I remember in one of his last outbursts someone linked the various fans used by the motherboard manufacturers and MTBF rating was hundreds of thousands of hours.
I just want to throw my hat in with the "shintel" lot. A motherboard fan was a genuine concern to me and a reason I didn't jump on the 3000 series.Its only a "genuine concern" for you in point scoring shilltel mode as usual. By the time the fan gives out the board will be long gone. And if it does somehow give out when the warranty expires there's this thing called "the internet" where you can type in the serial number and get a replacement. So toddle along.
