Caporegime
- 11 Mar 2005
- Leafy Cheshire
Looks like the pilot is still missing.
What do you think is going on here? Maybe towing a banner? Or something else?
Nice, where is it and what's your coverage like? I wonder what you're using for an aerial.I set up a new feeder yesterday on a pi4 2gb running buster.
Don't use a long USB cable, do it via PoE. I've got a 30m cat5 cable running from my shack to the top of my mast where the Pi 4 sits in a box with the official PoE hat.Thanks @Nazbit I am running a pi. Not sure I can find a usb cable long enough.
They're generated via polar.sh from here.What are you using to create these heat maps please?
I realised I didn't answer this - Yes, I found that range works best for me. I've got good coverage from my main receiver outside and this is my one in the loft so it's not too critical but it seems to work well enough.I've set between 3-5 from research. What made you choose 4-6.5? Trial and error?
