There is a "Liftgate Latch Position Switch" positioned somewhere near/on the boot lock.
It has four switches within it.
All four switches are connected to the "Liftgate Auto Closure Control Module"
One of those switches also feeds both the "BCM" and the "Cargo Compartment Light"
BCM then feeds the "Theft-Deterrent System".
- Something you could try:
- Remove the rear parcel shelf.
- Verify that the boot light is on.
- Shut the tailgate gently.
- Verify that the boot light goes out.
- Bounce the vehicle / push down on the tailgate - does the boot light come on / flicker?
- Try the above again, this time closing the tailgate with a slam - same result?
Thank you so much for the help. I'm going to have a mess before it goes dark
