Poco f2 would get my vote. No curved screen and no notches etc and cheaper.
Cheers dude, just looking around at best place to get it, wouldn't mind the 256gb ver.
It's officially been released today so you can get the 8/256 for 499 direct mi.com/UKCheers dude, just looking around at best place to get it, wouldn't mind the 256gb ver.
Should work. Has band 20. Unless the description is wrong.Hi guys,
I won a cheap pixel 2 on ebay for £80 from a seller in china. Before I won the auction he said it would work with Three UK, but since the end of the auction he sent me a message saying that he has now checked and it won't work with Three and can he refund me...convenient.
I think he's trying to weasle out of the fact that I got a good deal.
Here's the phone, anyone any idea if it will work? Or is he waffling. I checked and Three use 800mz and 1800mhz , which the phone listing states that it supports.
https://tinyurl.com/y73t86qh
Thanks guys
Hi guys,
Thanks guys
I'm pretty sure it will be my next phone when my pixel 2xl finally gives up. It's not far off but hanging in there.Cheers thinking about pulling the trigger on this right now, can't see the warranty or how to change colour, Grey does look nice but fancy the white or blue.
*Edit*
Just purchased it, cheers AndyCr15, Joelk2 & Psycho Sonny for the recommendation.
currently waiting patiently. =D
Any other requirements?What phone would you recommend for a budget of around £100 - £150? At that price I was thinking it would be better to get a second hand poco f1/ OP 5t, what other options are there?
Leaning towards the OP 5t as that is my current phone and it's worked well since I've bought it.
Ie screen size etc..
Which cases/screen protector would you guy recommend for my Poco F2?.
Cheers
Are they not all the same? Choose which style of case you want...
What phone are you using it on?I have to say that MiUi 12 is fantastic.
The best overall android OS I have ever used![]()
Isn't MiUi bloated? Used a pocafone F1, great phone. Let down with the extra bloatware.I have to say that MiUi 12 is fantastic.
Hoping it comes to the f2 Pro soon![]()
